Just out of curiosity...
GaryG in MD
>what's the difference between chain saw bar oil and, say, 5w30 motor oil, other than the color? ...Gary
GaryG in MD
Re: Just out of curiosity...
Bill Howatt
>I was told that the bar oil is "sticky" so it stays on the bar better.
Bill
Scott Hurley in N. VA
>I ran out of bar oil once, so I tried some motor oil. I had a cloud of blue smoke all around me. Didn't seem to damage the saw, but as soon as I could, I poured it out and got some bar oil. No more smoke.
Scott
Ken Oakley-Sunny St. Cloud, Fla.
>I have used 30W oil in my chain saws since day 1 with no problems. Was told to do this by a neighbor who worked for years as a lumberjack in Pennsylvannia.Syas it is all he ever used.
Brian Simmons, Heflin, AL
>I was told by a saw shop a few years back that the bar oil they sell is a blend of several recycled oils. I usually use old ATF fluid and have been doing so for about 25 years and no problems (no smoke either).
Ken Grunke from SW WI
>What I remember reading, probably in Popular Science or something, was that B&C oil molecules were chemically modified to be long and stringy. This accounts for it's "stickyness" as mentioned in another post.
I use it as a cutting oil on the metal lathe, and it's stringyness is apparent when I see it flying off in long, thin threads from the revolving work.
Pete in Holland, MI
>Have seen timber cutters use used motor oil, only one guy told me he dumps in a cheap equivlent of STP into a 3 gallon container to help make it a little tackier.
Seems motor oil isn't too bad on a saw. Just have to make sure there is enough.
Have used bar oil in mine most of the time, although discovered last winter while cutting some blanks, the thick gooey oil wasn't pumping very well, so I switched to some cheap 30W and that worked fine.
Bob Fawcett
>Any oil is better than no oil.
Just be sure you have something to lube the bar.
Robert D. Macgregor
>I wonder if anybody makes certified organic bar oil with vitamin E and aloe? Any oil is fine as long as it flows to the bar and never runs dry.
Interesting... thanks to all who replied
GaryG in MD
>My reason for asking was probably pretty obvious -- I ran out of bar oil and threw in some motor oil (with a wary eye). It seemed to work fine. Then I looked at the comparative prices and got the idea that if it worked once, it might work all the time. For the most part your replies indicate that this is true (not sure what happened to you, Scott). I suppose it's possible that the real high end saws might need something special, but I'm just using a 16" electric for cutting and trimming blanks, and the motor oil seems to work fine. Adding some STP is an interesting idea too. Anyway, thanks to all for your comments. ...Gary
