adapter questions
adapter questions
adapter questions
Robert Henderson
>I just got a new Jet mini lathe.
I have a bunch of 3/4"x16tpi faceplates and MT1 drives and collets and stuff that went with my old Craftsman lathe. I'd like to use that stuff rather than spend a couple of hundred dollars replacing it all.
Does anybody know -
Where I can get a 1"x8tpi to 3/4"x16tpi adapter?
Where I can get a MT2 to MT1 sleeve?
Do Morse taper adapter sleeves have a hole all the way through so I can thread a draw rod through it to use the collets?
Re: adapter questions
Russ Fairfield
>All of the above are available from the Craft Supplies catalog; and no, MT adapters do not typically have a hole drilled through them. If you want a through hole, you will either have to drill it yourself, or have a special adapter made by a machinist
Leo Van Der Loo
Sell the craftmans pieces and buy the proper ones
Leo Van Der Loo
>for your Jet mini, rather than introduce vibration or alining problems, you also shorten the already short center to center length available, just my way of thinking, OK
You can get MT sleeves, but they don't have a hole through them normally, but you can cut the end off and then you're able to use the drawbar, but your sleeve might like to stay in the spindle when you try to knock out the MT, just more problems than it's worth IMO
Bill Noble sells faceplates for a few bucks apiece, and MT are not expensive.
Have fun and take care
Leo Van Der Loo
Leo Van Der Loo
I should learn to type faster, yes like Russ said
Leo Van Der Loo
Allen Neighbors
>I got two of their Spindle Adapters. Drilled a hole through eacy of them after I mounted them on the Spindle. I suppose you could get a reamer that is a Morse 1 or 2 either, and use that after you drilled the hole.
Just a suggestion that you might think about......
