Re: Green Poplar Droplet 5224
Bruce Forrest
>Thanks everyone for the responses so far. In this piece, all of the actual hollowing is done from the bottom. Most of it is fairly standard, using a boring bar with laser and a steady rest. Then at the bottom of the hole (which is the top of the finished vessel), it gets a little trickier. I draw the final shape of the outside on the piece and hollow down to a point which is roughly 3/4 inch from what will be the top of the piece. The last 3/4 inch is exceedingly narrow as you can see. After the piece has been cut off, and reglued on the tenon exposing what will be the top of the finished piece, the outside of the top is shaped using the guidelines drawn on to guide the hollowing. Then it's a simple matter to use a 3/16 bit to drill the 3/4 inch to connect with the hollow inside. The tenon is removed using a vacuum chuck. All the rest is with a stronghold.
