We value your privacy.
>A friend gave me a vacuum pump. Nice compact little thing, it's from a piece of medical equipment(Travenol). Seems to work fine, although I haven't actually used it on the lathe yet. I'm in the process of making the necessary fittings.
There's a glass jar at the inlet that's supposed to have oil in it. There's a wick hanging down into the jar and you can tell there was oil in there at one time, but it's dry now. The jar says "Use Gast AD 220 oil or equivalent" on it. If I'm right that this is a rotating-vane type of vacuum pump, then I guess the oil is there to vaporize and provide some lubrication to the vanes - ?? Anyway, my questions -- where does one get some of this oil, or its equivalent? I see Packard and CS sell Gast pumps, but no oil. Is 220 the weight? If I use this thing, is it going to deposit oil vapor all over the inside of my bowl? Thanks,
>No it's not going to put oil into your bowl, it's sucking air out of your bowl, you will get a small amount of oil coming out of the exhaust port, air tool oil should be close to the same IMO, that's what we used in the car assembly plants air power tools, and it is very thin oil.
>I have a similar pump Dave, that I picked up on eBay about five years ago that I estimate is about 35 years old. It had a bit of oil in the jar and every once in a while I slosh it around to soak the wick. I searched the Gast site all over and never came up with much about these oldies, by will top up to at least the wick with some air oil, per the others' posts.
