Why I prefer turning over flatwork *LINK*
Ken Grunke from SW WI
>Over on the Woodturner's Resource forum is a thread titled "Dumb Shop Tricks...Add Yours". Or, what's the dumbest thing you did in your shop. I'll reconstruct mine here, then you ought to go look at the original thread--it's kinda hilarious (linked below)
Dumb Shop Tricks...
This was for a meditation bench I was making last November, with a single dovetail on the corner joints--
1). Decide where the pin goes, and where the tail goes.
2). Measure, and mark the tail board on the side that won't show.
3). Meaure again to double check.
4). Do sawcuts for the tail, using a Japanese pullsaw which is reserved only for the finest cabinetry work that you only do once in a coon's age (or two).
5). Clean up with a razor sharp chisel.
6). Place the end of the board with the tail cut against the other board, and mark out for the pin with a marking knife.
7). Cut the waste away from the pin using that wonderful Japanese pullsaw. Imagine James Krenov looking approvingly over your shoulder.
8). As the last piece falls free from the sawcut, you think to yourself "Hmmm Self, that was easier than I figured it would be".
9). Unclamp the board from the bench, and bring it over to the other board to check the fit.
http://www.kengrunke.frih.net/forumimages/stupidshoptrick.jpg
10). Collapse into a pile of sawdust, balling.
11). Pick yourself up, brush yourself off, and collapse back into the pile of sawdust, laughing.
WR thread: Dumb Shop Tricks...Add Yours
Re: Why I prefer turning over flatwork *LINK*
Norm Smith in Nova Scotia
>Ken, I was in need of a giggle. Thank you so much.
I have been there and feel your pain.
Norm
I've never done anything like that, honest!
Brian Hahn in SW Wisconsin
Been there, done that...
Peter Teubel
>Awhile ago, I was given a Jet bandsaw mobile base...free, because the third wheel / lift mechanism was welded INSIDE the perimeter of the base, not the outside (nice QC from the factory, eh?).
No big deal, I can fix that. I cut off the wheel bracket and grind down the welds on the frame nice and smooth. I then ground off the paint on the otherside where the backet will be reattached. Align everything and weld on the bracket.
Spent a few minutes chipping off the slag and wire brushing the weld. Sat back and admired my work, but something didn't seem right...
DOH!!!! I welded the bracket TO THE ORIGINAL (i.e. wrong) LOCATION!!!
Another couple hours spent fixing *MY* mistake....
Sir! Watch your language! There are....
>ladies present and gentlemen with refined sensibilities. We will have none of that in the shop. The image of defiling the sawdust is just too unseemly. What I am trying to point out is surly a typo, but there is a vast difference between "balling" and "bawling".
And I have never done such silly things personally, unless you count:
Gluing my hand to a boring bar with CA.
Looking for my ear muffs for an hour while they hung around my neck. (big clunky shooters muff, too)
Turning one the DP with the key in the chuck, thumps me in the chest and then I wonder where it went.
Solved the pencil problem by buying a huge box of slightly used pencils at the thrift store for a dollar and threw them into the shop, Everywhere. Maybe a thousand. Good for about a year.
Had a big black �Stop� mark on a piece with dado�s. Looked at it and it did not seem familiar until the exact instant I saw through it.
Thanks, Ken
Ruth Niles
>That is funny. I loved some of the posts on that link you provided. There were a couple that had me laughing out loud, maybe because I've done those things. TDRice had the funniest (which I have done!), he ran out of 320 sandpaper and went to the store and bought 220......
3 times! : )
>Thanks Ken I've screwed up so many things cutting them wrong or too short. I have pencils all over the shop because I can never find them. I'm still looking for a small screwdriver sized pry bar that I know is still in the shop. I've looked around every machine that I was near the day I used it. I'm sure I'll find it right after I buy another one.
The chuck key thing I've solved. I put a big magnet on my drill press and on my lathe. The chuck key always goes on that magnet. Except of course when I don't put it there, then the search begins.
Re: Thanks, Ken
Bill Crommett
>Barry : be carefull who you tell that stuff to. It may just be the reason you will be barred from handling sharp instruments.
MikefromTn.
>Had spent half a day building a new elevated television shelf in the new shop. Eight ft. high on a ten ft. ceiling. Safe enough OK, all set up and ready to finish out the day on the router table. In a rush I forgot to tighten the collet. When I turned it on the bit took off and I watched it make the most perfect arch,I swear it took 10sec. straight through the middle of a 27" Sony picture screen. No one hurt, I thought it was kinda funny. Wife didn't see the humor.
Steve Kubien
Yup, yup, and yup that one twice!
Steve Kubien
>Been there, felt the pain and the shame. Finally cut something the correct length, but out of square. Cut the dado, on the wrong end. Drilled pilots for #8 screws, only to find I am using #6. The sandpaper one is a classic. I do that every couple of months!
Thanks for the giggle.
Steve Kubien
Arghh! I STAND corrected!!! LOL
Mike Stafford
Mike Stafford
>But they are such nice looking pins.....
I would be embarrassed to mention my mistakes in the world of flatwork. Like sawing a box in two on the tablesaw and not rotating it end for end resulting in the cuts on the front and one end being 1 inch off the cuts in the back and the other end.
And God Created Male and Female..........
Barry Turner
Re: Sir! Watch your language! There are....
Jim Toews - Walla Walla, WA
>Barry,
How do you "turn one a DP"? I obviosly have a lot to learn, especially in the spelling department!
Cheers!
Jim
Busted....
>I'm sure Ken realizes I was razzing him. The god's reached down and tangled my fingers to get even for teasing Ken. I meant to say "Turning on the DP". This is the problem with letting the spell checker do your proof reading. I usually cut my posts and past them into a Word Doc and let it run spell checker. Then Paste them into the �post� screen. Clearly, I need more help than Word can provide.
Re: Busted....
>Barry,
My feeling is, if you can't take it, don't give it. In my case, payback is going to be a bear. I, too, was just joking around with you: your initial meaning was obvious, but in context, I just couldn't pass up on the opportunity...! At work they say my sense of humor is weird at best, and at worst it is best not discussed. They have a valid point.
Cheers!
Jim
Re: Busted....
Ed in Leaside (Toronto, Ontario)
>And I thought surely you were being surly. ;) (Yup, they gotcha again)
