Polyester Resin dust and dust collector
Roger Peterson
>Hey folks,
I'm a lurker who enjoys all of your company daily during my lunch period. I'm looking for info on polyester resin dust and/or fumes being drawn into dust collection system. I am casting PR molds and turning pens in a high school . Is there any potential for an explosion or fire hazard? With the amount of heat generated during the curing stage, I was wondering what happens with the dust if it is sucked up and contained in a relatively air tight container like a dust collection barrel.
I have witnessed spontaneous combustion with air filters from a paint booth that were not allowed to "air" out before placing in a barrel, not something I would like to participate in again.
Oh, and we are wearing appropriate masks, I believe the discussion has come up here before regarding proper ventilation and protective equip.
Thanks for any discussion on this,
Roger
Re: Polyester Resin dust and dust collector
Wilford Bickel
>I work with Polyester Resin and being a chemist see no more danger from the resin than wood dust PROVIDING you allow it to fully cure. With the work I use it for I allow at least a week for it to dry and harden before I turn it - in the high humidity here in the south I want all the "sticky" part of it gone before I turn it! Once it has fully cured and hardened it is an inert product just like any other plastic. There should be no spontaneous combustion from the fully cured product - you would only see that if you allowed some of the product to get into the wood shavings/dust that is still curing and developing heat.
Thanks, a little more on the cure time
Roger Peterson
>Does the PR cure inside out, outside in, or is it uniform throughout?
I have turned it within a day or two of having poured it, it seemed to be hard but.... is there more there that one is not able to see?
Is the cure time you are using just your general rule or is there a more accurate "safe period" for cutting into PR, for the dust possibly not being fully cured. Again this is in a school, they frown on me making big explosions (if they don't hear or smell it, I'm OK) :)
Re: Thanks, a little more on the cure time
Wilford Bickel
>The thicker the PR - the less catalyst it takes and the faster it cures. Most of my work is thin inlays and it takes longer to cure to the point of not being sticky. Left over material in the cup that I mix it in will be cured and totally dry long before the thin inlay so that is why I go with the long cure time. If you try to turn or sand it before it totally cures it will gum up everything from tools to sandpaper.
Thanks Wilford
Roger Peterson
>Thank you for your responses Wilford. I will make an attempt to post some of my student's work when he completes his first PR pen.
Roger
Re: Thanks Wilford
Wilford Bickel
>I look forward to seeing his work Roger - let me know if I can be of any further help. My wife is the real PR specialist and is always with me when I make a pour so we can get her involved if needed!
