Because
Mike Cunningham (Cape May)
>Because I'm a glutten for lots of stripping, varnishing, sanding and other forms of punishment!
Seriously, I've been told that the epoxy will not stand up to UV and needs varnish as a protective coat. As well, I've been told that varnish alone needs the "undercoat" of epoxy to truly protect the wood outdoors, particularly in a saltwater environment.
The number of varnish coats was to provide depth to the finish, a high quality appearance. I could certainly have gotten away with less, if I were looking for protection only.
Reading various manufactuers text and talking to wood boat guys around here, an old boat building area, regarding wood boat restoration is where I've found this info.
The console on the whaler is mahogany and was coated with several layers of paint. It required a tremendous amount of time and elbow grease to bring it back to a state that I was satisfied with. The reversible pilot seat was gone so I obtained plans and built one of solid mahogany. After all of that, I'd decided it best "err" on the side of overkill, plus I wanted that deep finish that I mentioned.
From West Epoxy:
The function of a finish coating like paint or varnish over an epoxy barrier coat, is to decorate the surface and protect the epoxy from sunlight. In doing so, the finish coating extends the life of the epoxy moisture barrier, which, in turn provides a stable base that extends the life of the finish coating. Together the two form a protective system far more durable than either coating by itself.
Protection from sunlight is a primary consideration in the selection of a finish coating. Long term UV (ultraviolet) protection of the barrier coat depends on how well the finish coating itself resists UV and keeps its pigments, or its shield of UV filters on the surface of the epoxy barrier coat. A high gloss finish reflects a higher proportion of the light hitting the surface than a dull surface. All other thing being equal, a white (especially a glossy white) coating will last the longest.
Most types of coatings are compatible with epoxy. Thoroughly cured epoxy is an almost completely inert hard plastic. This means most paint solvents will not soften, swell or react with it. However, it is still a good idea to build a test panel to assure coating compatibility.
