5/8 not equal to 3/4
eliot d
>I just got an unhandled Rolly Munro hollowing tool from Packard. It's 5/8 " in diameter. It fits perfectly in one end of my Hosolic (sp?) tool handle. so I suppose I'll use it in that. But I'd really like to use it in my Stewart arm brace and in some other hollowing rigs I have, each of which has a 3/4" opening. Can I just tighten the set screws in the 3/4" holders, or should I wrap some thin metal around the Munro first? I suppose I could try to get a custom-made reducer ( but it would only be a 1/16 " in wall thickness -- kind of difficult to make(?) ) Do I need one? Is there a solution I haven't thought of?
Re: 5/8 not equal to 3/4
Allen Neighbors
>Eliot, if your set screws are long enough, they will hold the shaft in the brace. But if you could get a scrap of thinwalled 3/4" copper tubing, it should be just the ticket to use as an adapter. It will be around 3/64" thickness... maybe even 1/16th. Their tolerances aren't too stiff, but it will work better than doing without.
You can drill a hole in the tubing, so your set screw will grab the tool shaft.
HTH... :o)
eliot d
>Allen Thanks. Just what I was looking for!
Re: 5/8 not equal to 3/4 *LINK*
Rick Allen
>Hi Eliot
Ask CA to make you an adapter. Or you can buy one from a variety of sources.
Kelton adapter sleve, 3/4 to 5/8 - Craft Supplies
Bill Noce
>Rick go to your local big box store get a pvc coupling or pvc that will fit over the tool than turn it down to fit your hollwing 3/4" hole. drill hole for screw cheat fix.
Bill
Allen Neighbors
>Good idea, Bill, thanks for posting. :o)
Stan Townsend
>To answer your question, Yes you can just tighten the set screws if there are two of them. I make several adaptors for size changes but it would not be necessary for your case.
http://www.elbotool.com
