Sanding in reverse - Safe?
Jerry Hall
>Recently I read a post about the dangers of turning in reverse, especially with an unsecured fixture. I have also seen lots of comments about sanding in reverse, but never from a safety perspective.
I only reverse the lathe for sanding, and at low speed. Sanding adds little force in the direction of unscrewing the fixture. If it started to come unwound (which it never has) I believe it would be immediately apparent before any harm done. Does this make sense to you?
Re: Sanding in reverse - Safe?
Bill Howatt
>Safe -probably with light pressure but the risk that it will unscrew does exist. Unless the speed is very low you would be surprised how fast they unscrew. It only takes about 8 revolutions typically.
Does your chuck/faceplate have a setscrew hole?
Bill
robo hippy
>Although I mostly power sand now, sanding in reverse does work, and really helps with hand sanding as the fibers tend to lay down in one direction. Use lighter pressure, and lower speeds. With experimentation, you can find out just how much pressure you need to use. I have had the chuck unwind more than once. If it comes loose, you just take your hands off of it, and it pretty much stays where it is until you turn off the lathe and comes to a stop. If it is a heavier utility bowl, and isn't at high speeds, you can just hang onto it until it comes off the lathe.
robo hippy
Ralph Watts
>Jerry,
The only safety issue is; Do you have a set screw on your chuck? Some brands have two. If these are cinched down, there is no problem sanding in reverse. In fact I turn in reverse from time to time but my chuck has two set screws and I have never had a problem. If you don't have set screws, be very careful...
Best regards, Ralph
Allen Neighbors
>Jerry, I sand in reverse all the time. If you install your chuck tight enough... (there's a thread about installing [stuck chuck] your chuck in the last few days) it shouldn't ever come loose from just sanding. It stands to reason you should also keep an eye on it.
If it has set screws, by all means, tighten them; but if not, just tighten the chuck with a little torque, and go ahead and sand.
I sand in forward and reverse in every grit, from both sides of my lathe, and have never had my chuck spin loose. Sometimes I use some pretty heavy pressure on my little free-roller sanders, too.
Hope this helps a little.
Thanks! Great Advice All
Jerry Hall
Re: Thanks! Great Advice All
>Jerry, you have gotten good advice. If you are at all nervous, set the set screws. (Not much effort on a valuable piece near completion.)
I have had a very small number of times when a piece unscrewed it self. Had one or two actually come off, but no disasters. They just fell onto the ways and there was no harm.
What works for me is to mount the chuck with a little snap of the wrist. Hold the shaft with one hand and give the chuck about a quarter or half turn twist quickly with the other. A gently bump. I find it takes about the same gentle bump to release it. I have Nova chucks with those hateful keys. I lock the shaft on the lathe and inert the key. With one hand holding the key firmly against the "stops" I slap the top of that hand with the other hand. I guess its about the same as snagging and unsnugging it with a wrench. (I should get a wrench, but I already have two hands.) Once it�s snug, it does not seem to tighten more and lock it self, but if you start with it loose and it self tightens, you could be in trouble. (The stuck chuck thread comes up fairly often.)
Allen Neighbors
>Barry, I took an old 1-1/2" (or is it 1-1/4)spud wrench (used by steel workers to line up holes in girders) and cut the point end off it, leaving a hand-sized handle. It fits the Chuck Adapter, and with the spindle locked, all it takes is a very slight bump with the heel of my hand to unscrew the chuck. (I use the little "wrist-snap" thing to seat mine, too.)
You can sometimes find these wrenches in junk stores.
