Jet Band Saw Blade
Jet Band Saw Blade
Jet Band Saw Blade
C.W.Stivison
>I have a new Jet 14" band saw with a 6" riser. The blade length called for in the Jet catalog is 105". This seems to be too tight and causes the saw to bog down. Even with the tension backed of as far as I can it still seems tight. Any suggestions on what I am doing wrog would be helpful.
Thanks
CW
Re: Jet Band Saw Blade
Russ Babbitt
>Have you tried a different blade?
Brian Hahn in SW Wisconsin
>My band saw also uses a 105" blade. Some blades are definitely shorter than others. I don't remember which manufacturer had the short ones. My advise is to get a new blade from a different manufacturer (brand). Some stores (like Woodcraft) carry several different brands.
Dennis Yoder
>Make sure that the upper wheel is releasing all the way and not hanging up or binding. I had to remove a corner to allow full travel. Dennis Y
That requires a larger blade
MikeF
>I posted a note on this topic last weekish.
This is not documented very well, but that saw uses a 105.5" blade (at least my DLX version does). This is documented in the manual that comes with the riser block.
