Kel Mcnaughton coring tool
Ken
>Has anybody here used or saw this tool used on a HF lathe?If so how was it set up.
Thanks Ken
Ken
Thanks Ken
Re: Kel Mcnaughton coring tool
Allen Neighbors
>I don't think the Harbor Freight lathes have a large enough motor. I've heard you shouldn't try the Kelton coring tool on less than 1-1/2 HP.
Greg Haugen
>Craft Supplies says 1 horse minimum. I do have people though that core on a Jet 1236, very S-L-O-W-L-Y. I personally would not recommend it. There is alot of torque on the lathe when using one. HF lathes don't have the bearings to withstand it in my opinion.
Greg
Ron in Drums PA
>I use it on a Jet 1236. It works fine, just maybe not as quick as a bigger lathe.
Bill Grumbine (Kutztown PA)
>Ken, you might be able to do it, but you would need the patience of Job. I know of a couple of people who core on smaller motor lathes like Ron, but the HF is going to be pushing it. Perhaps if you could find a way to borrow a system before you buy. Then, there is the other option of buying it, and then having to upgrade your lathe! You might find out you need a new lathe anyway if you cook the motor or bearings.
Bill
Denis Putland from Saskatchewan
>If you are thinking of spending the money for a coring tool then you have a very good reason to upgrade your lathe:):)
Hmm..?? perhaps getting the coring set up first would make the upgrade an absolute necessity.
When ever anybody does an upgrade they are all happier then a pig in ???? mud.
I know I sure was so happy with my lathe upgrade::::)))))))
Denis
Re: Kel Mcnaughton coring tool *LINK*
Steve Russell
>Hello Ken,
While I have not turned on your specific HF lathe, I have cored thousands and thousands of bowls using the Kelton Center Saver (KCS). I wrote and article (link below) on using the KCS, which includes a section that details my innovative "Fluid Pulsed" technique for using the system on low HP lathes. While the process is slower on a small lathe, it CAN be done... I have done it many times on 1HP lathes and a few times on 3/4HP lathes. If you have specific questions, I would be happy to assist you. Take care and all the best to you and yours!
http://www.woodturningvideosplus.com/center-saver.html
robo hippy
>Steve Russel's article has a lot of merit. You can core on a 1 hp lathe, but it isn't easy. The cutter on the standard set is about 3/8 inches wide. With the spear point, the shaving you remove is about
1/2 inch wide. If you can take a shaving that wide with a scraper, then you can core with it. The mini set from KM has a smaller cutter profile, and would be ideal for smaller lathes. The only problem here is that the tool rest sits a bit high for most 12 inch lathes, and the cutter does need to be at or slightly above center height. 1 inch above center is too high. One modification I made was to grind the point off so that the blade is square on the end. This results in a 3/8 inch wide shaving. It does not effect the cutting ability of the blade or how it tracks. I may have to try the concave thing on the face of the cutter some time.
robo hippy
Ken
>Thanks for all the respones.I already have the coring tool,got it for Christmas.I got the HF at a good price on sale.I already have a 2hp motor lined up for a 150 bucks which still leaves me at at less than 4oo bucks for the whole setup.But my problem is getting it setup on the darn lathe.
Thanks Ken
