Bowls buff and lacquer
Dominic Greco in Richboro PA
>Gil,
You wrote:
"....Deft lacquer and buffed. 7.5"wide by 3.5" hi and a 5/32" wall. I really need to get those bowl buffs for the inside, do any of you use them (and like'em?)."
I have a set of the Beall bowl buffs. But I really don't use them as much. I bought a set of the small (3" or 4") wheels and end up using them most of the time. They do a good job on the inside of most bowls.
I notice that you mentioned that your finish is lacquer. However, I wouldn't use a buffing wheel to polish a lacquer finish. It's too easy to buff right through the lacquer (DAMHIKT)! The buffing wheels are more suited to oil finishes that are absorbed into the wood, rather than a lacquer finish that is built up and "sits on top" (I know that the fist couple coats of lacquer are somewhat absorbed. I'm just trying to make a point)
If you want to get a super glossy finish, I would recommend using automotive polish. 3M Finesse it, or Griot's Machine Polish work really well with lacquer. before applying them, I wet sand with Micromesh all the way up to 15000. Then I polish with Griot's Automotive Machine Polish, give it a coat of Renaissance wax and get a finish you can see yourself in!
See ya around,
Dominic
