hollow form help
hollow form help
hollow form help
gary s clarke
>I would like to learn to turn hollow forms and am wondering how to turn the bottom with such a small opening in the top. Any suggestions would be appreciated. thanks in advance.
Re: hollow form help
There are special tools for hollowing
>Basically, it has to do with straight or bent tools that you insert through that top hole, Gary, and carefully remove the material from the inside of the blank. It can be pretty scary and frustrating for a while until you get used to it, and you should resign yourself to blowing up a lot of pieces before you get the knack, but it's like anything else: practice makes perfect. You also have to stop frequently to blow out the chips.
There are many popular brands of hollowing tools, including those sold by our advertisers Don Pencil, oneway and Packard Woodworks, as well as those by David Ellsworth, John Jordan, Rolly Munro and others. I'm not sure there is a clear consensus on which types work best.
I think you need to check out one of the available videos on the subject. Maybe people will recommend their favorite tools and teaching aids.
Beware the slippery slope. :-)
Cheers,
Carole Valentine
>Gary, if you are wondering how to finish off the outside of the bottom after hollowing, there are several ways. Lot's of people use a vacuum chuck. I don't have one of those. If I don't have enough wood to just turn the bottom and part it off, I reverse chuck by turning a jam chuck from scrap to fit into the opening. Bring the tailstock up, make any adjustments needed to get it running as true as you can, then finish the bottom with light cuts from a sharp tool and sand. The little nub left where the tailstock is can be easily carved off then sanded by hand. Sometimes I use a piece of that white rubber shelf liner over the jam cone to provide a little additional drive friction. Others will probably chime in with their method.
gary s clarke
>thanks for your help. when you are too old to learn your dead, and I have a lot to look forward to learning.
Wally Dickerman in Arizona
>I suggest that you start your HF turning by turning pieces with a large opening so that you can get an idea what the tool is doing in there. You didn't say what kind of tool you'll be using.
Wally
gary s clarke
>Wally, I have a tool from Don Derry and have been practicing with it on open bowls about 5 in in diameter. I think I have a good feel for how it works but I am concerned about reverse turning the bottom. thanks
Brad Vietje
Brad Vietje
>Hi Gary,
Hollow forms are my favorite part of turning (well -- besides finding burls !).
Probably the best way to learn this is in person, from a more experienced turner. Short of that, video presentations are very helpful. I can highly recommend John Jordan's video called "Hollow Turning" which can probably be borrowed from some turning club video collections, but is well worth buying for your own collection. He shows how to do this with hand-held tools, and his careful presentation and teaching style work very well.
Safe spinning,
Brad Vietje
Newbury, VT
Dick Hines
Dick Hines
>Gary, I use PVC pipe couplings as jam chucks to finish the bottom of my hollow forms.
If you can get a copy on the latest AAW mag there is a artical on hollowing through the bottom and the pluging the hole in the bottom.
You can also save a large piece at the neck while shapeing the HF. Part this off and put it aside. Then you can make a larger opening in the top. Whe finished hollowing you can turn a tenon on the saved piece. Glue into the HF and drill a small hole. Then blend the shape into the rest of the HF.
I have been making bottles like this lately. I only drill 3/16" holes in the neck. Gives people something to think about.
Dick Hines
Forgot
Dick Hines
>After you turn the neck down to flow with the rest of the HF use a skew to from a few groves to cover up the joint.
Bill Clark
>Gary, I'm new at hollow forms but I've turned a few acceptable pieces. I was scared to death at first but found the Don Pencil set up worked very well for me. I have very good control and the Pencil set up provides a variety of tool tips for different situations. I drill a hole in the blank the size of my opening and start cutting inside the hole at the top and slowly work my way down to the base. After a while you will learn to feel the high spots. I also use a steady rest on long pieces to hold the piece in case I get too aggressive. I've been turning buckeye that has lots of holes in it so I can't use my vacuum chuck to turn the bottom of the bowl. I've made donut chucks that have worked well for me. I've included a picture of a small simple one I made.
gary s clarke
>thank you all for all the tips and suggestions. You are a great group.
Re: hollow form jam chuck w/rod (long)
Allen Neighbors
>Gary, in order to reverse and turn the bottom of hollowforms, and to keep from putting too much pressure on the top of it, here's what I have done. (I turn a lot of forms with 1/2" openings)
1. I mount about a 5 inch long piece of scrap wood in my chuck, and bore a 3/8" hole through the center. Then, leaving about 3/4" of an inch of flat at the chuck, turn the rest of it into a long cone... all the way to the hole.
2. Next, up close to the chuck in the 3/4" flat, I bore a 13/64" hole and tap it for a 1/4 x 20 bolt to use as a set screw.
3. I insert a long 3/8" rod (mine's about 12" long) through the cone, and use the set screw to hold it in place. I have a little piece of leather glued to the end of the rod that will make contact with the bottom of the HF.
4. Wrap the cone with some thin foam (Walmart sells "Foamies" in the craft/sewing section-48cents)to protect the opening in your HF.
When you put the HF onto the jam chuck, make sure the leather-tipped rod end is against the inside bottom of your form. Bring up your tailstock, push the form and the rod, until the opening just makes contact with the cone. Tighten the set screw, to keep the rod from slipping farther in, and then tighten the tailstock.
You're now supporting the top of the form, centered, and the pressure is only on the bottom. You can then finish turn the bottom, except for a little nub in the center. When finished, cut off the nub, and sand it by hand or a small chuck-mounted sander.
Hope this gives you some ideas. Any questions, email me.
gary s clarke
>thanks again for all the help
Bill Clark
>Allen, I have used your method and it works well. Here is another idea when using the donut chuck for a natural edge piece.
Andy DiPietro
Use a Kristen Cone or Woodchucker Mandrel *LINK*
Andy DiPietro
>Gary,
I use a Kirsten Cone which supports the HF by compressing the bottom and guiding the the top. This is very safe and easy to use. Kim Blatt wrote a procedure on how to make a Kirsten Cone. He lists the part #'s from mscdirect.com. I ordered all the parts except the Nylon. You can save money by making the cone out of wood.
Click on the link then Newsletters, then September 2006 Newsletter and the go to page 3 The Kirsten Cone.
http://www.keystonewoodturners.com/
If you would rather buy one Craft supply sells the Woodchucker Mandrel #995-6000 for $47.99
http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=995-6000
I just ordered the Woodchucker since the Kristen cone I made was not very concentric, but it still works well.
I also use Don Derry's hollowing system and I am very pleased with it.
Check out my last (April 16th) posting for some tips on using Don's hollowing tools.
