Finish over Pyrography?
Dominic Greco in Richboro PA
>Quick one here. I have a cherry platter that features a scorched/burned band about 3/8" wide (the rim frames the platter). Since I used the small ball tip pen to make divets and do the burning, it's pretty even and black.
I was going to use Watco's Danish Oil as the finish but just realized that this may cause the "black" from the scorched area to run.
Is there a chance that will happen? If so, whats the best way to stop this? Seal with shellac? Sanding Sealer? Spray lacquer?
Thanks,
Dominic
Re: Finish over Pyrography?
Jennifer@Indy.USA
>Dominic,
After burning ALWAYS rub the burned area down with rubbing alcohol and a toothbrush. This will get rid of the residue and the yellowish tint at the edges of your burns. Then you can apply the finish of choice. It makes your burned lines and designs look much crisper. Molly pointed this out to me on one of my pieces at Louisville and I haven't looked back. It's like night and day as far as the burns looking crisp.
Jen
Wally Dickerman in Arizona
>Dom, as Jennifer says, apply alchohol to clean up after burning. I usually use my regular Daly's tung oil finish. If you want make the burned area even blacker, apply black gesso which you can get at an art supply store.
Wally
Molly Winton
>Jen and Wally pretty much covered it. As Jen mentioned I use rubbing alcohol on some cotton to clean up any smoke haze where burn and raw wood meet. Where I brand heavily (my basket weave pattern) I also brush this with a horse hair brush (shoe shine brush works great) to get any ash removed, and then I finish my pieces with Danish oil. I use this exclusively on my pieces because I want a matte finish, but one that will pop the grain. I've never experienced any running by following this procedure.
This is great stuff!
>Geez, thanks to all of you for the quick responses! This is awesome! You know I'm printing this out to PDF and saving it in my "Woodworking Wisdom" file.
Thanks again,
Dominic
