ADVERTISE HERE - FREE TRIAL
First Sea Urchin Ornament
eric_s
>After seeing the beautiful ornaments done by Ed Moore and Kurt Herzog I had to try some. Here is the first attempt. Purple Sea Urchin with Mahogany. Comments are welcome. Personally, I think that the beaded section on the icicle is too large and maybe I should have been about half as long, coming to a point where the bead is. Color in the pictures is not coming out real well. Using a Canon PowerShot SD100 any advice here is greatly appreciated.
Eric
Re: First Sea Urchin Ornament
Second pic of same ornament
eric_s
Ornaments
Ed Moore
>Eric,
I was unprepared to find myself mentioned in a post. Since you seem to be asking for suggestions, my first thought is that the bottom or lip of the finial could be undercut at a 45 degree angle. You may find it necessary to file or sand off some pips on the shell to allow the finial or icicle to seat evenly.
My reaction to the icicle was that the weight was in the wrong place. I don't think that the sea urchin ornaments need as long an icicle as the usual Bob Rosand globe ornaments. That said, I think the diameter of your lower bead is right for the upper bead and I would taper it like mine and as you said.
Super!
Norm Smith in Nova Scotia
>Eric, for a first attempt, I think that is great. I sure the next one will be much improved.
norm
robert davis
>very nice ornament asis. shortening as you suggested. would work. a matter of personal preference
Bob Way, Canton, MI
>One of the things I need to work on is my spindle work. I sure do admire you folk who have a knack for doing it so nicely.
Bob Way
Canton, MI
ebd
Re: First Sea Urchin camera color (v. long)
ebd
>I had a Cannon Powershot S100 (same as yours?) that I killed when my underwater case leaked in Dominica. I now have a S500 (and a better UW case). I found auto mode sometimes had color shift, especially in low light without flash or in artificial light. In manual mode there are usually a boatload of settings that allow you to mess with all sorts of things.
Both my cameras have/had settings for:
1. light source (sunlight, cloudy, tungsten, floorescent, and possibly custom - Note: this is really "white balance" and has a large effect on the color of the picture
2. ISO speed - I'm not sure if this has any effect on color
3. light metering method - again don't know
4. exposure compensation - this has some effect on the color
5. photo effect (vivid, neutral, sepia, b/w., sharpening) - vivid & neutral affect color
You will have to read the manual to find the settings and play with them to find out what they do. If you go this route be sure to write down what each setting does for each situation. To be sure, a lot of work.
What I usually do is to try to take my pictures under natural light but not in direct sun or on bright but cloudy days. I get the best focused and framed picture I can and leave it go at that as long as the bowl color is accurate. I use a grey background that sometimes comes out light blue. Sometimes I will use a photo-editing program to do some minor color correcting or cropping as long as the bowl color remains accurate. My brother-in-law, who works for Kodak and is an avid photographer, woud cringe. Maybe someday I'll get "a round tuit" and learn all that stuff but honestly I'd rather be working in the shop or fishing.
Re: Ornaments
eric_s
>Ed -
Thanks for the tip on sanding the shell - they seem so fragile I was afraid to do anything to them so I used CA glue to build up a slight bead for both the finial and icicle to sit on.
I was asking for suggestions.
Next one will have a shorter icicle.
Thanks,
Eric
eric_s
>Thanks for the tips. I have played with the manual settings, however, I always seem to get more color shift, i.e. whites come out blue/violet, than with the camera in auto mode. Guess I have some more research to do, good thing the images are digital and not film or I would be wasting a lot of film. :-)
Eric
eric_s
>Thank you.
Re: Ornaments
Ed Moore
>Eric,
I use a small file or a Dremel with a small drum to sand down the pips and make the opening more regular.
I put Krylon Triple-Thick Crystal Clear Glaze on the shell, usually before I do anything else to it. That helps them stay together. Before I did that I had a beautiful sputnik shell collapse in my hand. Keep up the good work.
Ed
ebd
ebd
>I know what you mean. It's a mystery to me. Especially after you add in all the stuff you can do in an editing program - contrast/brightness, color balance, tone balance, modify color map, hue shift, color shift... AGHHaaa - my brain is all aching and wracked with pain. That's why I wait for the right day and shoot everything at the same time. Even then it takes multiple trys. The only thing I'm sure of is "don't zoom in macro mode". Otherwise it's a crapshoot.
