We value your privacy.
>Hey all, I have a log section of Holly 12" dia. x 14" green and sealed. I would like to turn a hollow form with it but have never turned Holly. What do I need to know about turning a hollow form with this wood? Thanks for any info. Sean
>HI Sean, holly is one of my favorites. It's going to move quite a bit, but if treated in the usual manner, it should work out fine. I've experienced holly that was like butter to turn, while other samples were extremely hard and dense..still great to turn.
>I understand that if you wait too long to at least rough it out it will turn gray/blue. I got a section of a tree at auction, it had be recently cut and sealed. I waited about 8 months before I cracked it open and was rather surprised to see how gray it had turned. I was still pretty but not very white at all. I asked about it here on WC and was told that it happens if you let it sit to long.
Good luck and don't forget to show us the results!
I turn quite a bit of holly. It tends to move more than other species. It will also develop cracks easier. Be sure to maintain an equal wall thickness and seal end grain if roughing and leaving to dry. Having said that, I find it cuts like butter. It also takes finish very well. I often use watco followed by the Beall, finished in that manner, to me it looks like alabaster. Besides forms, I also use it for collars and finials. Recently I've experimented with dye as well as gesso and acrylics and like the results.
>Should I turn this end grain or side grain? The reason I ask is I was thinking of turning very tin start to finish and letting it do it's thing with movement. If this is a bad idea, please let me know.
My opinion is to twice turn it. It's so prone to cracking that I'd be afraid to say "turn it thin and see what happens". It will absolutely "do it's thing" and move and I fear it will also crack, regardless whether turned end or side. If turning end grain I sure wouldn't try to include the pith. You could also try an alky bath. Me, I'd rough it side grain, seal, dry and re-turn it down the road.
>...and it worked out fine. If you turn it side grain with the pith in it, make sure you cut off enough end grain from the log to get down to really green wood, otherwise it will check. Also, a trick I learned from David Ellsworth: after you turn the outside, wrap it in plastic packing tape. This keeps the moisture in as you turn the inside.
Holly shrinks a lot, as many have testified, and quickly. I've had pieces that went elliptical before I was even finished turning them.
>Sean, I have found that boiling helps, both with cracking and graying. I also have some billets I have put in the freezer for storage until I want to turn them. So far no change in color while frozen. Don't know what will happen when I take them out to turn them.
>OK I hope I didn't mis this,but I have apretty good size pile that I got from a tree that was felled last oct.So it has been sealed and cocer since then.I hope to tun some in a week or so.Does this move like cherry?I turned a bunck of that while in FL and I had turned it to about 1/2" wall thickness and sealed it and it all warped and split so bad I lost it all.So should I campair these to woods?and with these woods should I seal the whole roughed out bowl or just around the edges?Sorry for the long post,but I just don't want to lose all this wood also.(even though the cherry was free wood)Thanks.
>I've been turning freshly cut holly recently . It will definitely warp and may crack. I turned a small thin open form that warped a lot. THAT was the piece that everyone bid on at a silent auction I was just in.
