You can actually turn black palm, right?
Dave Belser
>I happened on a small length of what I assume is black palm, it has beautiful black straws that run through a brown matrix. You see black dots when you look at the end grain. I believe that I have seen it turned on occasion.
So here we go, cut a 4" length of the 2x2" stick and chuck it up. It doesn't look like it will be easy but should be pretty when done. Pick up a gouge and try some rough cuts - the "straws" start splintering out everywhere. Gee I guess I should have expected that. OK, lets get it close to round, sharpen all of the tools and try some light cuts. Looking better for a bit and then little chunks of black splinters pop out. I can't seem to make one full light cut with out ripping out one of those little black straws!
Boy is this stuff ornery! way worse than the dry Fir I tried.
I suppose I could pull the individual black straws out and do tiny spindle turnings with them :)
Having never seen the stuff before, I suspect that the piece that I have might just be dry beyond turnability. I did try soaking the little piece in thinned lacquer and it helped a bit but the lacquer didn't really penetrate the wood that much.
Is there some trick to it (besides good technique and sharp tools) that I'm not aware of? Is it any easier to turn when green?
- Dave
Re: You can actually turn black palm, right?
>Dave I've turned a bunch of black palm wine stoppers and love the stuff. I don't remember having any of the problems you talk about. The stuff I had cut well, sanded extrememly well and held the finish and polished up beautifully. I suspect you either got a different species than I got of perhaps the stuff goes bad.
Russ Babbitt
>I've used black palm mostly for inlays in boxes. As long as you cut in the proper direction with the grain supported it should cut just fine. Otherwise I find it can be difficult.
Charles Burton
>I have turned several pens and bottle stoppers from black palm. Some cut better than others, when they start to come apart like you describe I soak them in thin CA Glue. Then after they are good and dry I used the normal steps for what ever I am making. Hope this helps
Charles
Thanks, I'll try it again some other day
Dave Belser
>I think that the end that I started on is rotten. I can pick the strands of black out with my fingers once the ends are exposed. I'll try another chunk from the other end, and maybe some CA glue.
At this point, today is a loss. Started with power out from 8 am till noon, so I ran out to shop for wood rather than sit around and wait for the power to come back. When I got back I found about a 1/2" of water on the shop floor, mostly around my lathe #$%!!
Tomorrow.
- Dave
Dick Hines
Dick Hines
>A friend brought me a piece he wanted turned into a pen for his father. It was as dry as a powder horn. I ended turning the pen down close to the bushings and soaking the palm with CA.
It did make a fine pen. I would love to turn some that had not been drying for 15 years.
eaglesc
>I have turned it with the grain and across the grain.
Gouge?
What's that?
I use a skew that is honed on a diamond stone and CA.
The skew came from HArbor Freight.
eliot d
>My experience is just like yours. I turned a hollow form about 5 x 8 in. I loved it! I think it's beautiful stuff. Perhaps some samples are not so hot.
