Cherry bowl with Pyrography
Dominic Greco in Richboro PA
>Hello Everyone,
Here is a cherry bowl I completed just this past Saturday. This one of those bowls I roughed out back at the end of in 2005 and totally forgot about. It had been alcohol dried at the time. So by the time I got to it, it was BONE dry. I wanted to do something different with this and decided to continue to experiment with pyrography. I used my newly purchased "Coarse Hair" Optima pen to draw these lines. BTW, even after 45 minutes of use, the pen tube was still comfortable to hold.
The two beads about the rim were formed using my handy dandy 3 point tool and are approx 1/8 wide. While the space between them is about 1/2" wide. The burned lines bordering the beads were formed using a guitar string (where permitting) or a piece of black veneer.
This piece of cherry had some assorted cracks, pitch pockets, and a large void near a knot. These were filled with a mix of charcoal, coffee grinds, and CA glue.
While I'm pretty happy with the overall effect, I know there is a lot of room for improvement. I think that the next time I try this type of design I will use the skew pen to make thinner, deeper lines. I also will make it so the pattern features more lines that are closer together (these were about 3/16" apart). I also need to practice my "control" so that I get uniform lines. One difficulty I was never aware of until I tried this was holding the bowl steady while you worked. After making this rather simple design, I have even more admiration for Molly Winton, Wally Dickerman, Jennifer Shirley, and those others that make this look easy!
Specs:
Outer dia.: 9 1/4"
Height: 3 1/2"
Wall thickness: 3/8"
Base dia.: 3"
Sanding Method: Dry sanded to 600 Grit and then burnished.
Finish: Watco's Danish Oil
Final: Buffed with Beall System followed by Renn Wax
What are your thoughts about this bowl?
Thanks for viewing.
See ya around,
My ugly mug
Dominic
Re: Cherry bowl with Pyrography
Keith Tompkins
keith tompkins
>HI Dom, I think the form you turned is very well done. That's important, especially when pyrography has been added. The burnt design shows restraint, and compliments the piece very nicely...the bead and the pyrography being placed together works well, much better, imho, than using them as separate elements. I like the simple rim treatment as well. It all works.
Ruth Niles
>Hi Dominic,
I just saw this on WoW and loved it there as much as I love it here! You really did a great job.
>Dominic That's a great looking bowl. I like the space between the beads and pyrography. I really like the foot detail. On my computer the photos look green. I'm not sure why that is. You didn't have any flourescent lights on while you were shooting did you.
Hi John
>John,
Thanks for the compliments. No, I didn't have any fluorescent lights on at all, only the halogen lights. And the white balance was set for Tungsten.
I used the background as my gage for color (is that a workable practice?) On my computer screen, the background appears to be the same color (or VERY close to it) as it is in real life.
BTW John, I used just the (1) overhead 250W Halogen on this photo shoot. I was trying to eliminate the hot spot the side mounted 500W halogen was giving me. No matter how I moved it, that hot spot stayed! So I placed a card in front of the light, and it blocked off most of the light. That seemed to work. In the end, the pictures came out somewhat dark. Then I used PaintShop Pro to adjust the gamma correction slightly .
Could that be the problem?
Maybe I should mount the 500W halogen on the overhead beam?
Dominic
Thanks Ruth!
Thanks Keith
>Keith,
Thanks for the compliments about the form. I really worked hard to get it just right. After turning the beads, part of me wanted to leave the bowl with no pyrography at all! I just liked the shape so. But in the end, I decided to add it, but with a "light" hand. I was really concerned with the pyrography overwhelming the rest of the bowl.
Dominic
Steven Antonucci
Another Beauty, Dom.
steve antonucci
>I've always loved the finishes you achieve. The inside of the bowl is flawless and perfect, and quite juxtaposed to the outside. I have one in my shop that's almost the same, except the hole goes through.
Do you use a small metal ruler to make the lines straight or are they all freehand? If not a ruler, any bit of aluminum will probably do well (since it won't conduct heat).
See you around.
Steve
Thanks Steve
>Steve,
Thanks for the compliments!
Actually those lines are slightly curved. The photo makes them look straight. I got sort of anal about the spacing so I measured the diameter at the right spot, drew a circle in Autocad, and used the "Measure" command to put a dots on the circle 3/16" apart. That gave me a visual of what the pattern would look like. Then I made a cardboard template for one curve leaning to the right, and on the other side of th template, leaning to the left. Then I drew them in with a pencil (w/HB lead). Then it was as simple matter to burn/draw on top of the lines.
See ya around,
Dominic
Nice work
Ed Kelle
>I like the bottom a lot too. such a nice piece of wood, you did a great job
Thank you Ed!
>Ed,
Thank you for the compliments! And I'd like to compliment you on your bowl shown in June's FWW gallery.
I was just looking through the magazine and saw your name under that spalted sugar maple bowl! Well done indeed!
Dominic
Re: Hi John
>I would definitely use the 500 up high and then the 250 for any fill light options. It sounds like your doing the right things. Bowls will give you a hotspot of sorts no matter what. It's that parbolic curve that does it. Sometimes you have to move the light very far to the back to get the reflection below the rim. When you do this the front gets dark. Then you add another light up front low enough so the reflection won't show but this causes funny shadows and can be tricky to control. I usually use a mirror in this situation. I mount it as close as I can to the bowl but low enough not to be in the photo. I use the cheap plastic mirrors. You can get them from glass companies pretty inexpensively.
I use the background to judge color most of the time. It could be just your monitor and mine aren't calibrated the same. It's very easy to throw the color off when your tweaking things.
Steve Kubien
Love the burning
Steve Kubien
>Hi Dom,
I really like this piece. The burning doesn't overpower the wood. While others have been drawn to the base, it is the rim that really catches my eye. The proportion looks good to me and I really like the inward slope. How long do you think the drawing and burning took? When/if I start to experiment with burning, this is the sort of 'motif' I would be interested in.
Thanks,
Steve Kubien
Ajax, Ontario
Hi Steve
>Steve,
The laying out of the lines, making the cardboard template, and the drawing took about 30-35 minutes. The burning, about 45 to 60 minutes. I had to take a break cause my hands were starting to ache from holding the bowl at an awkward angle.
See ya around,
Dominic
Steve Kubien
Re: Hi Steve
Steve Kubien
>Thanks for the info. I was afraid it would be a 6-hour ordeal (!). It's on my to-try list but still a ways off top billing.
cheers,
Steve Kubien
congratulations ED
>Me too. I forgot that I saw that in bowl in FWW. I just started reading it. Beautiful as always Ed.
Russ Fairfield
>A classic bowl well done.
Thanks Russ!
Mike Brazeau
>Hi Dom.
Very pretty bowl for lots of reasons - lots going on with the cherry, great execution and nice use of beads and burnin'. Does that point tool make it easy!
Mike
Mike Rubes, Apex, NC
>Hi Dom,
This piece is awesome! Thanks for showing the pics. I love the burn treatment, it is really topnotch. I love a piece of wood with character and this one has it in spades!
Thanks for the pics, really great stuff.
Sorry about the snow!!!
Mike
No snow, but I really wish spring would show up in Apex, NC!!!
Brad Vietje
Great Job, Dominic !
Brad Vietje
>Hi Dominic,
Great job, Dom -- this is a real beauty ! I like the pyrography and its simple design, the raised rings (beads?) that set off the detail band, the pattern you drew/burned in, and I especially like the slightly uneven, not-quite-perfect lines, which shows just enough of the hand of the maker to look handmade, but finely done. I also like the shape and the placement of the bowl within the blank, allowing the large bark inclusion to be featured, but not allowing it to penetrate the inner surface of the bowl. This shows good design and skill, and restraint that comes with experience. Going one step further, I think the shape of the rim is just right.
I guess I like everything about this bowl, but I must say you are wrong about one thing -- there may be SOME room for improvement, but not a lot !
Safe spinning,
Brad Vietje
Newbury, VT
Re: congratulations ED
Ed Kelle
>Thanks guys, its nice to see them show some pics of turnings.
