A Strange box, take 2
Dave Belser
>OK, now that I've worked out the image thing....
A strange box, 4" high x 3" diameter:
Dave Belser
Re: A Strange box, take 2 (links fixed)
Dave Belser
>One more time..
Ok, now that I've worked out the image thing....
I've been working on idea for another peice and the base (maple) is a test for the other idea. I've added a machinists cross slide to my lathe, the box is a machined cylinder, the only surfaces that were turned "by hand" are the outside top and bottom. Here is a picture of it open:
This shows the part I was experimenting with. The closesure between the top and bottom is milled like that of a safe, 4 distinct steps, each step face is .050". The lid actually fits losely, you can twist it freely, but if you pick it up by the finial, there is enough of a suction that the bottom will lift off the table before dropping off.
Needless to say, I couldn't bring myself to discard this "practice" box and lid.
Now for the "finial".....
I aquired a small amount of questionable cherry burl, it simply had too much insect damage and voids to useable for much. I also hadn't had a lot of experience turning burl so I made 3 strange spindle turnings and kept them around for possiable use as finials somewhere down the road.
What I like about this peice is that the finial and the box DON'T go together. Especially when you open the box and see the machining. At this point, if I was to make another finial the stem and bulb on it would be more graceful. As it was I had all I could do to remount it and turn the base of the finial enough to fit the recess (for chucking) that existed in the top of the box.
I think I did alright for two leftovers.
Comments and critques wellcome!
- Dave
Troy German
>I like the multi-stepped lid fitting very much, and I like the natural inclusion (NI) on the finial, though I agree that the shape of the finial could use some work. However, I disagree that the finial and box don't go together. The step down construstion inside the box makes me think of outdoor ampitheaters, where natural and man-made stuctures work well together. So, for me the NI on the finial is a better choice than a finial that has a more polished look.
Thanks for showing your work,
Troy
