Lathe Height
Lathe Height
Lathe Height
RevDoug
>My lathe is great. Would change a thing. Except for the height. It is adjusted as tall as it will go and is still too short for me. What would you all suggest as the best, most stable way to raise the Nova 1624 about 4 inches?
TIA &
Turn 'em round,
Re: Lathe Height
Re: Lathe Height
Ed Moore
>Doug,
One option is to get some of the excellent red-wheeled swivel casters like they have at Woodcraft and install them. They lock and the swivel locks. We have them on the club Jet 1642 and they work great. And when they are unlocked the lathe rolls smoothly and without "attitude". I have considered them for my Oneway 1018, which I have on two 4 x 4's (left and right).
Ed
Re: Lathe Height
Re: Lathe Height
Mike Cunningham (Cape May)
>My Vicmarc, which I have no intention or reason to move sits on 4X4's. My Delta, which I do move about, I have on the same type casters that Ed described, both for movement purposes and to attain desired height. My Vicmarc mini I installed on a cabinet also on locking casters.
With something unbalanced, the Delta will wiggle a bit.
If it were me and I had no plans for moving it, I'd put it on a solid base such as I described for my Vic.
Mike
Re: Lathe Height
Re: Lathe Height
Sean Troy
>I use pressure treated 6x6's under my PM 4224. Works perfect. I lagged them in through the pre drilled holes in the legs. Gives more stability at the same time if you cut them several inches longer than the leg width.
Re: Lathe Height
Re: Lathe Height
>Sean,
Since you've extended the 6 X 6's beyond the length of the existing legs, has the one beneath the headstock leg gotten in the way of your feet?
Mike
Re: Lathe Height
Re: Lathe Height
Allen Neighbors
>Doug, this is what I did with mine. The 2x6's under the feet raise it 3.5 inches. Spindle height 49", and love it!
Hope this gives you an idea.
Re: Lathe Height
Re: Correction: 3 inches
Allen Neighbors
Re: Lathe Height
Re: Lathe Height
Sean Troy
>The 6x6's do not get in the way at all. I only have them sticking out 3" past the outside edge of the legs on the front and back.
Re: Lathe Height
Re: Lathe Height
Ed Wujciak
>Glad you love your lathe as I love mine. When you requested advice on the purchase, I told you it would be too low but that's not a reason NOT to get it. I have mine on 5" of blocks but hope eventually to put it on a movable device which also raises it. Meanwhile I'm just havin' fun and makin' a mess.
Re: Lathe Height
Trestle legs?
Dominic Greco in Richboro PA
>To raise my Jet 1642 up to to a more comfortable height, I added a set of trestle legs at the same time I added a ballast box. They also gave me the benefit of increased stability.
See ya around,
Dominic
Re: Lathe Height
Re: Lathe Height
Lan Brady
>Allen,
Do you have a maid for the shop? lol
Lan
Re: Lathe Height
Thanks Sean
>I've considered extending my 4X4's to span additional joists but have concerns about "getting in the way".....
Re: Lathe Height
Dick Hines
Re: Lathe Height
Dick Hines
>Doug, I have a PM3520. When I got it I knew the height was no high enough. I have mine sitting on 4x4's. Then I Placed some 2x4's aroung the leveling feet. My spindle is at 50". After I got the lathe on the 4x4's I used the adjusting bolts on the legs to get the lathe level.
Re: Lathe Height
Re: Lathe Height
Allen Neighbors
>LOL. No maid. That was taken the day I finished the lathe installation. Besides, if I had a maid, she'd get in trouble everytime I needed a tool and couldn't find it. :o)
Re: Lathe Height
Re: Lathe Height
RevDoug
>Thanks everyone. I am indeed loving my new lathe. Your advice has confirmed my thoughts on raising the height. I've got to get some measurements and then I'm off to the lumber yard for some lumber. My shoulder blades thank you.
Turn 'em round,
