continental spindle gouge
peter kolb
>Hi, What is the grind geometry of the continental spindle gouge for roughing and coves in spindle turning? I do not see it in the grind library on this site. Thanks for your help. Peter in south central NJ
Re: continental spindle gouge
>I sharpen mine more like a spindle gouge than a roughing gouge. I'd have to check the angle but it's probably somewhere around 45 degrees. Not real sharp but not real blunt either.
Russ Fairfield
>This is what I use for turning pens, goblets, weed-pots, etc. It is a 1/2" Continental Spindle Gouge from Sorby.
Russ Fairfield
Re: Yep-mine looks just like Russ's,...
Jamie Donaldson
>... and I sharpen it with my Wolverine jig, but with different settings than my bowl or spindle/detail gouges.
peter kolb
>Jamie Donalson, Mine does not look like Russ's but I used the wolverine attachment with the vee pocket; the same one I use for the roughing gouge. What setting do you use on the vari-grind attachment? I knew when I ground it that it did not look right and it was real grabby. Thanks Jamie, Russ, and John.
Mike Cunningham (Cape May)
>Check your email and I'll see you at Tuesday's meeting.
Mike
Leppikallio
>Exactly. Now if there only were "continental" spindle gouge say 3/4" - 1" with more substantial tang like in P/N roughing gouge that would be the dream tool. Great for slow curves and hollow form roughing. But I don't think there is one?
>Henry Taylor makes something similar. I don't think the sides are as thick but you can grind it to look almost exactly like Russ's tool
Gordon Seto
>"Exactly. Now if there only were "continental" spindle gouge say 3/4" - 1" with more substantial tang like in P/N roughing gouge that would be the dream tool. Great for slow curves and hollow form roughing. But I don't think there is one?"
This may be your dream tool! Doug Thompson loaned this tool to me and I took this picture. It was a 7/8" bar milled to 3/4" shank on a P&N ultimate handle. It has everything you want plus A-11 steel.
Gordon
Leppikallio
>That looks quite potential. I think I'll have to try it one day too... Thank you Gordon.
Doug Thompson near Cleveland
>Gordon, thank you. With a different grind this could work well. I have this ground to use on the curve inside of a baseball cap.
If anyone wants a special tool made tell me the diameter of the stock, lenght, the radius and the depth of the flute. Another batch will be sent to be heat treated in about 3 weeks.
Re: continental spindle gouge? Not quite
Russ Fairfield
>By definition, the Continental Spindle gouge has a UNIFORM THICKNESS around the entire perimeter of the tool because it is rolled from a flat piece of bar-stock.
