vacumn chuck
bhenr99
>Is it easy to hook up a vacumn chuck system to a Jet mini lathe and are there any plans ? I have the vacumn pump. Thanks for any help.
Bob
vacumn chuck
bhenr99
Bob
Re: vacumn chuck
>I may be an hour or so before I get out there but I'll take a photo of my set up it's really easy. It is just a piece of wood turned to fit the handwheel and has a bearing adaptor to go to the vacuum pump hose.
Re: vacumn chuck
Curly Smith
>If you haven't already downloaded the article then you might want to visit William Noble's site and download his article on vacuum chucking.
go here: William Noble Website
Click articles
Click All about Vacuum Chucking for wood turners and wait for the pdf to download
Re: vacumn chuck for jet mini
>bob Hope this is clear. I'm redoing it shortly so I hope my two photos will explain it well enough. This shot is the vacuum adaptor I'm using now. It is actually a modified version of the one that comes with the Nova 3000.
Basically it is a piece of wood that is glued in the jet mini handwheel. It's is center drilled. I use clear silicone caulk to glue it in. Turn a rebate that fits whatever bearing you buy. I buy bearings with 1/2" ID. the outside doesn't matter because you can turn the rebate in the wood to fit. Use a piece of wood that doesn't move or use plastic or aluminum. The plastic decking material is perfect. I used plywood in this instance. Make this a really accurate fit so the bearing will stay in place while using the vacuum chuck.
Then get a 1/2" pipe adaptor with a barb on one end to fit your hose. This is 1/2" to 3/8 barb. Turn the threads down to be a really snug fit in the bearing. You can easily do this with a scraper in the lathe. If you don't have a way to hold it simply chuck up a piece of wood and center drill it a hair smaller than the barb. Drive the barb in the hole and your ready to turn. Nylon barb to thread adaptors also work well.
When you've turned the threads down epoxy this into the bearing being careful not to get any epoxy on anything other than the inner race of the bearing.
You will need a small piece of closed cell foam to go between the bearing and the wood when you intall it to actually use the thing. This helps seal the vacuum. If the bearing won't stay in while turning you may have to jury rig some sort of holding device.
>This is the one I'm going to build later this week and shows you all the parts you need. 3/8 barb to 1/2" pipe adaptor. The bearing is 1/2" ID and maybe 1 1/4 OD. The OD doesn't matter as long as it's not big for the wood you use to make the handwheel adaptor.
The last piece is the wood for the handwheel. I taper the front to fit inside the handwheel. Then I gripped it lightly in my chuck to turn the rebate to fit the bearing. I'm going to make the new one out of recycled plastic decking material. It's perfect because it doesn't expand or contract. This make the bearing fit better.
If you have any questions feel free to e-mail me. I have a PDF file showing other ways of making vacuum adaptors if anyone need it just e-mail me. I will probably write this up and get it on our club website later this week.
Re: vacumn chuck
Nelson
>If you don't want to spend time making one you can buy the Oneway rotary adapter,the 3/4-16 LH adaptor for their Stronghold chuck,remove the the handwhell and you are in buisness.
