Open staved vase
Open staved vase
Open staved vase
Jimiles-Charlotte, NC
>New method I have been experimenting with. Open staved & segmented combination. Bloodwood, walnut, cherry. Comments welcome
Re: Open staved vase
Troy German
>I really like this one, the concept and the shape. In my mind I want to see it revolving, like on a Lazy Susan. The open staves would have a nice effect as they let through changing bits of light.
Thanks for showing,
Troy
Carol - Strawberry, AZ
>How did you DO that!?
Bob Fawcett
>Very interesting piece. I would also like to know how you do this. I can imagine some of the construction, but it seems like turning it as it appears you would have issues with the lack of support between the staves. Do you use some sort of spacer arrangement while turning?
Thanks for posting.
Allen Neighbors
>Beautiful, Jim... what patience you must have! Thanks for posting it.
Jim Terry
>Jim, This looks very nice, I like the combination of woods. This one reminds me of a closed stave vase you brought up to our meeting (PTWA) in Mar. Thanks for showing. Jim
>Troy:
Yes, I am trying to find a small light source to put inside it that would rotate and shine light from within out the open spaces. I do art shows and I think this would be a big hit.
>Carol
Basically you start with 2 segmented rings for the top & bottom. I have used 24 segments. This keeps the uprights closer. The segments are about 2 -3 inches deep. The upright "staves" are flat pieces about 2 - 3 inch wide. You glue it all up. This gets a little challenging. Add a segmented bottom & waste block. Turn, add top rim and turn. There is actually very little turning since there is very little wood. The back side of the staves do tend to split out since they are unsupported. I'm still looking for a solution to that. So far I cut them as clean as I can and sand off about 1/4 inch to get rid of most of the split out wood. Give it a try!
>What crossed my mind with the staves was to have the backsides of them already shaped before the glue-up. That would eliminate the 'hollowing' and cutting of the unsupported wood. Would that work?
>Carol:
I think it would work to some degree. It would not allow you to get the inside truly round. The staves are prettty close on the inside, and not much of a problem, it the outside where they are further apart and not supported that is a worse problem.
>Understood. Thanks.
