sticking chucks and faceplates
>This seems to be a common problem among woodturners. I'll post what I do and hopefully hear from others. First, keep the threads and face side of the drive spindle clean.
Lube the spindle face and threads lightly. Ever since Stephen Russell suggested using air tool oil I've been doing that and have greatly reduced problems with the chuck sticking. Wipe it on the spindle and using a paper towel wipe it back off. You won't get it all and what's left will greatly help keep the chuck from sticking.
When you put the chuck on, screw it on lightly, then take your chuck wrench and tighten the chuck. How much pressure you put on the chuck wrench will be how much it takes to get it off. I've been doing that ever since John Jordan showed us this technique and guess what. He's right. Never spin the chuck on so it hits the face of the spindle and never never use the lathe power to get the chuck on. Doing this will jam it on so you can't get it off.
All chucks and all lathes aren't made to the same tolerances and of course wear and tear takes a toll. If you still have problems with sticking after the above techniques use a nylon spacer between the chuck and spindle. This can create some vibration on longer turnings but I haven't found it a problem. Use something that doesn't compress if you make your own. cutting your own washers from milk bottles works well but it's a little slick and you may have problems with the chuck coming loose on lathes with electronic brakes.
Those are my tips. Let me know what you all do differently.
Re: sticking chucks and faceplates
John Dillbeck
>I do basically the same as you except I only tighten finger tight. Like you say never spin a chuck on or tighten by running the lathe. Both are like using an impact wrench and can apply very high torques to the chuck/spindle.
Bob Moffett
Bob Moffett
>I went to a workshop that John Jordan and Lyle Jamison did and they recommended spraying the spindle and face of the spindle with WE-40. It works for me.
Bill Luinetti
>I've used nylon washers for 10 years with no stuck hardware or vibration problems.
Kevin Clay
>Things get stuck on the spindle if you do not get them on tight enough to start. If something is not tight on the spindle then during cutting the accessory can spin a bit and get tighter. If it is tight enough to start it will not get tighter during turning.
regards
Kevin
Re: sticking chucks and faceplates *LINK*
Wilford Bickel
>John,
I do most things you do except I like a very light coating of Firepower FP40 lubricant/protector instead of the air oil. I found this product through one of my other hobbies (shooting) and discovered it protects all the tools in the shop from moisture with such a light coat it will not transfer to anything I am working on. This product is supposed to bond to the metal. In addition it gives enough lubrication to allow the chucks to thread freely and the tailstocks to slide yet lock off without slipping. At one time they would send out a small 1 or 2 ounce trial bottle for free - since I started buying it in the big bottles, I don't know if the trial bottles are still available. It would not hurt to ask.
I do agree - DON'T EVER SPIN ON THE CHUCK/FACEPLATE! Thread it on slowly until it meets the shoulder and is solid - then on my units I lock the allen screw.
Firepower FB10
Wilford... Thanks for the link!!
dwr
George Hicks
>I avoid WD-40 because, over time, it gets sticky and creates a mess. I have used Anti-Seize Lubricant for such applications (a very little bit goes a very long way) and wipe most of it off, leaving a good film, after burshing it into the threads and onto the shoulder of the spindle.
"Break Free", a firearms cleaning/lubricating product, also works very well.
Re: I have used WD 40 on....
Jamie Donaldson
>.. all my lathe beds, and a lot of other things, for many many years, and never had a bit of problem with build-up or stickiness? I rub it in and wipe most of it back off- no apparent residue.
Lynn Edwards
>I also use a product borrowed from the shooting group. It's called Remlube and is available in the sporting section of your nearby big box store. It also puts a coating on the metal that stays there a long time.
