Source for Norton SG Wheels??
Greg Haugen
>I was wondering if anyone knew of a source for SG grinding wheels, 8"?
Yes I know Packard and Craft Supplies carry them but I thought there was a source that was under 100?
Greg
Greg Haugen
Greg
Re: Source for Norton SG Wheels?? *LINK*
Tommy Holmes
>Try this link. You definitely want the K grade wheel.
http://www.sharpeningsupplies.com/Norton-3X-Blue-Grinding-Wheel-K-Grade-P101C20.aspx
Re: Source for Norton SG? - Cutting Edge Tools *LINK*
Brodie Brickey
>Cutting Edge Tools has them.
http://www.cuttingedgetools.com/Onlinecat.htm/WebCatalog/Grinding.htm
They have good prices on a number of items.
Regards,
Brodie
CuttingEdgeTools
Thanks-I'll try the site that advertises here.
Greg Haugen
>I'll try Sharpening Supplies-they help sponsor this site by advertising.
Greg
Re: WC Marketplace Page Links...
Allen Neighbors
>don't work for me. What's up with that... anyone have any idea?
It says to click the advertiser's banner... but they don't click.
Tommy Holmes
>They didn't click for me either but you can right click and then "open in new window".
Dale Long
>Just a note re. these grinding wheels. It is my understanding that these 3X Norton wheels are NOT the same SG type popularized by the ledgendary Jerry Glazer which are considerably more expensive. They do not work nearly as well according to Kirk DeHeer, who works for Craft Supplies. I think some more info. about these two apparently different wheels is in order. Can anyone comment about this?
Tommy Holmes
>I had a set of Norton 3X wheels from Hartville Hardware that were wore down very quickly. I asked the different wheels on WC, you can do a search for "grinding wheels" and get several different threads. The difference from what I can tell is the hardness of the wheels. The ones from Hartville are maybe an H hardness. The ones needed for sharpening are I or K, preferably K which are a little harder. In earlier threads I gather that the ones from CSUSA are the K hardness. I haven't used them so I can't comment on them but there is a world of difference between the H hardness from Hartville and the K hardness I am now using from SharpeningSupplies.com. Hope this helps.
Bob Fawcett
>I have a real SG wheel. It wears very slowly and cuts very well. I don't know the exact difference between this and the 3X wheel, but from the discussions I have read here, they are not the same.
Looking at Norton's site, the 3X wheel is listed on the consumer site, and the SG wheel is listed on the industrial site.
Doug Thompson near Cleveland
>Sharpeningsupplies will deliver a Norton 3X 8 inch "K" wheel to your door for $50.
For the money this is a very good wheel and should last many years. The "K" grade is a hard wheel that doesn't groove like a softer "I" grade. I have used a 46 grit to rough grind tools and love it but this is too course for everyday use.
I haven't used the 80 grit "K" long enough to form a opinion, so far it looks good but then again I use a green wheel to sharpen my personal tools.
Rich Egan
>Greg: I have always used Norton's industrial wheels. They make aluminun oxide wheels in a 32A and 38A bond. The 38A's are usually white, while the 32A's are grey, but color is not always an indicator and may vary. Look at the label. The number code indicates what the abrasive type is, the bond type, size of abrasive and hardness. In my experience, the 32A seems to hold up better and groove less easily than the 38A. Depending on the steel you grind, you may want some friability, or surface breakdown of the wheel to expose new abrasive, or the wheel may load up and need frequent dressing. Get a norton bonded catalog at our local distributor and look it over. You can also call Norton if you have an application question.
The SG wheels are a seeded gel bond using a ceramic abrasive. Supposed to be very sharp, hard and cool cutting. They are often purple or pink and look porous. I have no personal experience, but people seem to like them. They are probably more expensive than a 32A or 38A wheel of the same size.
http://www.ind.nortonabrasives.com/Media/Documents/S0000000000000001035/Norton%20Full%20Line%202007%20Vitrified%20Toolroom%20Wheels%20Technical%20Info%20and%20Cross%20References.pdf
Bob Fawcett
>The SG wheel I have is blue and all the other SG wheels I have seen are blue.
Dave Anderson (Pac NW)
>Hartville woodworking $42.00
Gordon Seto
>The 60 & 100 Grit Norton 3X wheels from Hartville are not suitable for turning tools. They don't have a hardness alphabet rating on. They grooved real easy even with the lightest touch. I had to redress the wheel very, very often. They are the most expensive wheels for HSS tools.
Gordon
