Carbide cutters
CCollier, Pasadena, Tx
>Anybody have a good source for 1/4 - 1/2 inch round cutters like those used by the Elbo tool and others. TIA
CC
Carbide cutters
CC
Re: Carbide cutters *LINK*
ebd
>New Edge Cutting Tools
P.O. Box 282 Plantsville, CT 06479,
Fred Smith
860-628-4642
http://www.newedgecuttingtools.com/welcome.htm
Allen Neighbors
>You might try this page. You can get them a lot cheaper here, I believe.
http://www.carbidedepot.com/detail.aspx?ID=17640
Re: Carbide cutters
ebd
>Do you have a link that will allow the uninitiated to decipher the codes. For example, though I can see the shape from the cross-section I have no clue what the differences are between RCGT, RCMT, RDMT, and RPMT. Also in almost all cases there is no indication of diameter or thickness. At 5 & 10 per pack, that's way too expensive to buy blind.
Re: Carbide cutters
Allen Neighbors
>This link, below, is for an insert that a friend uses, but I'm planning on ordering it, also.
The min order qty makes them expensive, but these cup shaped bits will gouge out like a bullet thru the wood. If you dont have all the angles correct when you present this bit, it will grab and scoop out a furrow big enough to put your finger in. You have to start with the cutting edge verticle, then rotate SLIGHTLY to the left.
The "R" means it's "Round" and I think the C means it's carbide. I'm not sure of the other meanings of the coding.
This URL has links that will lead you to an explanation of the codes.
Re: Sorry, here's the link. *LINK*
Allen Neighbors
ebd
>Thanks for your reply, unfortunatly I'm still in the dark. I'm sorry, I guess I wasn't clear enough about what is confusing me. I can find my way to the page you linked to, I just can't seem to find any indication of either cutter diameter or thickness, let alone the diameter of the mounting hole, if it's threaded, and if so what the thread is. From all the information I can find, the cutter diameter might be .125" or 1.25". All the parameters I cited above are essential for me to pick the right cutter to mount on the tools I have.
Re: Okay, here ya go. :o)
Allen Neighbors
>On that link I gave you... over on the right side, below the search feature, there is a link that says "Technical Resources"... Click that.
The page that will open has a bunch of links. The seventh one down is the Insert Designation Chart. Click that, and it will tell you what the codes are.
There are also other links that will explain what else you might want to know.
The cutters on the page I gave you are about 3/8" to 1/2" in diameter, and have a hole in the center for about an 8mm screw. I haven't checked really close in a long time, so I'm not sure. But you can find out by searching their Technical Resources page.
Hope this helps. :o)
ebd
>Thanks ever so much. Sorry to be such a dunce. I've finally got it thanks yo your help.
Re: You're welcome... any time. :o)
Allen Neighbors
