Gluing Question
Gluing Question
Bob Moffett
Gluing Question
Bob Moffett
>I have been learning to make some hollow forms turning endgrain. I have been coring out part of the end to make it easier to hollow the inside. I have been gluing back the top after the bottom is hollowed and the inside of the top is shaped and have been successfully using Titebond III to glue the wood together (green wood). Tonight I went to work on one that I had glued up last night and after finish turning the top, the glue joint came loose and the top fell off. Should I be using a different type of glue to get better results. This is the first one I have had to fail, but I haven't done that many.
Thanks in advance for ya'lls help.
Re: Gluing Question
Re: Gluing Question *LINK*
Darrell Feltmate
>Bob
For wet wood I would use either CA or one of the urethane glues like Gorilla glue. Titebond needs a dry surface and if you are hollowing slightly green or even more fun, very green wood, the adhesion will be less than sure. CA may soak into the wood and give a problem with finishes and the urethane tends to give a dark line but neither should be a problem after your finish cuts and sanding.
Around the Woods
Re: Gluing Question
Re: Gluing Question
>I'll second Darrell's recomendation. If you are turning dry wood the Yellow glue will work but since it's end grain you may need to take an extra step. Endgrain soaks up glue and you may have a starved joint. Coat the endgrain with a thin layer of glue and let it soak in for a minute or so. Then put more glue on and put the wood together. This usually improves the glue joint considerably. End grain to end grain is still pretty weak although I've made quite a few 2 part hollow vessels that were dry wood and haven't had a glue failure. They weren't very large vessels.
Re: Gluing Question
Re: Gluing Question
Jimiles-Charlotte, NC
>Agree with above, I find that if you will let green wood sit and dry for 3 - 6 days yellow glue will work
Re: Gluing Question
Re: Sometimes you might try
Allen Neighbors
>a hair dryer on the spot where you put the glue... I'd let it sit for a couple of days, too, then use the hair dryer. But I think I'd try Weldwood glue... I think it might not be affected by the moisture as much as the yellow or white wood glues. I could be wrong about this, too. :o)
I just know I don't trust the Gorilla Glue... as prone to catches as I am.
Another thought: Try Industrial Strength Hot Glue. It will hold my wooden face plates. (thanks to Darrell Feltmate for this idea. :o))
