Turning while Sitting?
ChuckS
>Help-
I just got back from the Doc, & she tells me I need to stay COMPLETELY off of my ankle for the next couple weeks. I tore it up playing in the snow a couple months ago, and it has not healed yet. Anyhow, I guess I'm off work for a couple weeks & need to do someting to keep my sanity.
Has anybody had any success turning (safely) while sitting? I have a PM 3520 & also a Jet mini mounted on a table. Obviously I won't be turning any bowls or anything :-(
Normally, I try to move my whole body to control the chisel, and can't figure how to do this while sitting.
I remember a discussion about this not long ago, but cannot find it now.
Thanks!
ChuckS (gimpy)
Re: Turning while Sitting?
Darryl Hansen
>See if you can get your medicaid/Surgeon/Physical Therapist to get you the cahir they use for leg problems in the shower. They are plastic seated and have adjustable legs. I broke my hip and find it possible to sit on it in front of the lathe. Unfortunaetly SWMO will not let me turn it on. But next time she goes to play bridge who knows what the mice may do??? Darryl
Fog Tanner
>One of the guys in the woodturning club I belong to has several lathes (one is a mini lathe) for "sit down" turning. He had polio as a child and can't stand on his feet for long periods. His latest addition was a Oneway, which he had some new legs made for. They lower it down to a comfortable hight when sitting. He uses a swivel chair and has no problems. I have used it and had no problems moving around with the gouge when turning a bowl. If I were doing a lot of boxes I could get real use to it. The key is having a good swivel chair with good casters on it. If somehow, I should live long enough I can see having one of these when the legs finally go.
As far as safety, it is no different than any other lathe. If something comes off it is just as easy to sit and watch it as standing. You can actually move pretty quick in a good swivel chair.
Frank G ( Ingleside Texas )
>It would seem half my body parts are fake or monel, stainless, plastic or ???. I'm still working in a semi labor job. If you can afford the loss go for it. If you don't have a financiel loss I don't understand youn ?
Thanks!
ChuckS
>I'll give the swivel chair a whirl (haha).
I'm self employed building boat covers & this is my high season. I should be working 12 hours days if I want to make ends meet for the rest of the year.
If I can turn something it will be mentally therapeutic for me, and maybe I can sell enough to buy a decent beer- also therapeutec. Just not around the lathe :-)
It's only (hopefully) a couple weeks. I just don't sit still very well.
Thanks!
tm
>i dont stand so
i do bowls & hollow forms from a chair on a bench mounted nova dvr.
i still have all my original parts including digits & teeth
so i'm inclined to believe it can be done safely.
one of the reasons i couldnt buy a pm or a oneway is because i needed
space for my knees underneath the chuck & headstock to get in close.
email me anytime if you have questions.
john
eliot d
>I've seen an Ellsworth video in which he straddles the lathe. Apparently he prefers this position when hollowing a vessel.
Steve in NC
>I asked the same question in November 06. I was about to have surgery on my knee and had to be non weight bearing for 9 weeks. I ended up parking my larger lathe and turned on my jet mini. I mounted it to a bench with open space beneath and used a stool. Worked great.
Good Luck with the healing
Steve
