Don Derry's Hollowing System
Tommy Holmes
>I've been wanting to check out Don Derry's Hollowing System and possibly to buy one. I am not finding it on his website. Does anyone know where to find out more about it and ordering information?
Re: Don Derry's Hollowing System
Tommy Holmes
>Would like to hear some pros and cons also.
eliot d
>I love the Don Derry Hollowing system -- but not for anything too big. For large work I prefer Dr. Keith Clark's Spin Doctor rig. If the piece is not too big, I reach for the Derry first because it's a snap to set up and the laser x-y adjustment is superb (there's no lash back so the laser dot stays in place. With several others I have, you have to go back and forth when adjusting the dot. It's a PITA. There is a slight problem with the Derry laser in that, although there is no lash back, the dot will move around when you first twist the laser tube in its holder to turn it on. The twisting itself causes the dot to rotate all around. But once it's turned on, the x-y adjustment is a pleasure to use. I believe Don is working on a larger version, but I haven't heard anything about it recently. The Elbo system is great, too, but again not for anything too large. What I like most about it is that there is no metal rubbing on metal so the system can't possibly hang up the way most do. It definitely has draw backs, though, because of the way it must be positioned between the headstock and tail stock quill, thereby limiting the size of the turning that you can fit in there -- unless you have a very long bed. And, even if you did, there just isn't enough support at the elbow joints to handle large pieces. For large pieces the whole thing starts to wobble up and down because of the lack of support in the middle.
Re: Don Derry's Hollowing System *LINK*
Russ Babbitt
>Link below.
Don Derry
find Don Derry's Hollowing System here
Bob Elliott
>http://www.fulmerwoodworking.com/tools/tools-hollowing.html
donaldderry.com  *LINK*
Russ Babbitt
Link
Mike Squire
>I just called the number on his web site. He answered the phone himself and shipped it out very quickly. The normal setup of his tool is for turning with the lathe running in reverse, so it's cutting on the back side. It can be reconfigured to turn with the lathe going in the normal direction. If you do that, you lose a little bit of vertical clearance when you reverse the laser holder. Since my lathe doesn't reverse, I switched mine. It wasn't enough of a loss to worry about and it hasn't been a problem. Overall, I really like it.
