Wirebrushing?
Wirebrushing?
Wirebrushing?
Greg Haugen
>This may be a dumb question, it wouldn't be my first, but how do you "wirebrush" a piece?
Where do you find a good brush?
How far do you sand a piece before wirebrushing it?
Once the piece is where it needs to be is it just simply "brushed" with the grain??
Does the "brushing" create the final surface or does it then need be "steel wooled" to clean it up a little further? Any other words are there "fuzzies" that need to be cleaned up?
Sorry for the dumb question. But thanks for your time.
Greg Haugen
Re: Wirebrushing?
Re: Wirebrushing?
Russ Babbitt Jr.
>When it come to texturing, try anything. There is no correct method. One method would be to get a small rotary wire brush, used to remove paint, and chuck it in a hand drill. With the lathe and hand drill running run the brush against the workpiece. You can play with different speeds and directions to create different patterns.
Re: Wirebrushing?
Re: Wirebrushing?
Bill Hale / Woodspinner
>No steel wool on a wire brush surface. It will snag and attach to the wood.
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Wirebrushing?
Re: Wirebrushing?
Ron McKinley
>Bill: Does that mean you sand lightly after wire brushing? .....Ron
Re: Wirebrushing?
Re: Wirebrushing?
Ron in Drums PA
>Just enough to knock off any fuzzies
Re: Wirebrushing?
Re: Wirebrushing?
Troy German
>Thanks for the dumb question. I'm interested in what people have tried.
Troy
Re: Wirebrushing?
Re: Wirebrushing?
Russ Babbitt Jr.
>A piece should be finished as you would any turned piece. Some flaws or tools marks may show thru. By finished I mean sanded, no finish yet applied. You could also do a bowl with a raised rim textured. You can use a hand held or powered brush. As has already been said don't even use steel wool. Use a fine sandpaper to remove fuzzies. I would also recommend a spray on finish. Some wipe on finishes have gunked up in the texture.
Re: Wirebrushing?
Re: Wirebrushing?
>Just about anything and any brush will work. Powered or by hand. I like to use a really soft brass brush to clean up the work after using a stronger brush. I use a 2 1/2" steel wire wheel most of the time. I put it in the drill press and the move the vessel under it. You can actually sharpen the wire wheel. run it backwards (that must be why they put reverse on a lathe) and hold a medium grit stone up to it. This raises a slight burr and makes it cut cleaner.
Do a simple test board with any wire brushes you have. I buy any of the cheap brass wheels I find at the hardware store and then label the ones that seem to leave a good pattern on the wood. Try with the grain and across the grain. Don't, I repeat, don't use the brush you use to clean your gas grill. that is unless you really like the dark dirty look.
Re: Wirebrushing?
Steven Antonucci
Sometimes I use this
steve antonucci
>it gets a tenon at the back to be held in chuck, and a 5/8 "nub" with hole for a bold. I've used this for 4 years, an it's variable speed, since it runs in my lathe.
As others have stated, try everything. I've used it along the grain and across it, before and after scorching, and everything in between. Just watch your fingers (I wear gloves-let the debate begin about gloves at the lathe!) cause if it touches you, you get 20,000 little tiny scrapes in about 1.2 seconds.
Steve
Re: Wirebrushing?
A little different but
Don Henthorn
>I have been making some chimes lately and have brushed the 1 1/2" aluminum alloy tubes with 150 grit sandpaper. I wrap tape on one end and stick it in my scroll chuck and hold some 150 grit paper in my right hand around the tube and turn the speed to about twenty or thirty rpm's. I slide my hand slowly up the ube as it turns and can do most of the tube that way and then turn the tube around to finish it. Looks great. Then I began wondering about doing that on a turning. Haven't tried it yet but hope to get aroundtoit.
Re: Wirebrushing?
Re: A little different but
Bernie
>Done with a kutzall disc
nice feathery effect.
Bernie
