Salt Shaker
Salt Shaker
Salt Shaker
bhenr99
>I made a peppermill for my wife and she wants a matching salt shaker. Never made one and see the process is different because it is 1 piece. On the peppermill I was able to make a tenon to hold it in the chuck to drill hole and finish turn the mill. On a salt shaker I see drilling from 1 end and when I turn it around to drill other end you do not have a tenon to work with. I hope I explained this as not confuse anyone. Bottom line I guess is what is the process in making a salt shaker opposed to a peppermill? Thanks for any help.
Bob
Re: Salt Shaker
Re: Salt Shaker
Fog Tanner
>I believ it was the last issue of the AAW magazine that had an article one what you are wanting to make from start to finish. Seemed like a cute little thing to make and fairly easy.
Re: Salt Shaker
Re: Salt Shaker
bhenr99
>Fog Tanner in his post memtioned the AAW magazine. What does the AAW stand for? Thanks for any help.
Bob
Re: Salt Shaker
American Association of Woodturners  *LINK*
Don in Northern Arizona
http://www.woodturner.org/
Re: Salt Shaker
Re: Salt Shaker
Bill Hale / Woodspinner
>Is it a salt shaker or grinder she wants. The shaker is just a lid in a hole whereas the salt grinder is similar to a pepper mill with different material for the grind mechanism. Each are available at Craft Supply or Packard and others.
Good turning and be safe
Bill in Casa Grande, AZ,
Re: Salt Shaker
For a simple shaker, not a grinder,
Don Henthorn
>I would just use a glue blank and turn the outside shape to completion except for the very top which would be the glue block end, then drill the counter bore for the stopper and then the cavity for the salt. Finish everything you can reach and then part off making the top the shape you want as you part off. The salt exit holes can be drilled on the drill press. Of course I believe in KISS.
