Light Pull friction drive
Mike in Shreveport/Bossier City, LA
>I'm thinking about taking my scrap bin and turning about fifty or so light/fan pulls for a craft show I'm participating in next week-end. Has anyone used the friction drive that Packard and Craft supplies sells? It seems like the wood quits spinning if I don't have the pen mandrel tight enough when making pens. I'm not sure I'm confident that the drive will be positive enough to keep the wood from stopping when I cut it with the friction drive. I don't want to have to tighten it so much that I split the wood. Any ideas? I don't plan on getting the light pull kits that use the 7 mm tube. Just turning scraps with holes.
Thanks,
Mike
Re: Light Pull friction drive
Fog Tanner
>I have the one that Best Wood sells, also a friction drive. It doesn't require a 7mm bore, but is stepped. I generally drill a hole the size of the chains I am using (I but them by the 100 from C.S.) and a sort counter bore on the "bottom" end to receive the end of the chain and engage in the drive. I have not had any problem with the wood splitting, it only takes as much force as is needed to spin the wood. I like to use Aromatic Cedar, which is prone to splits and have not split a one. Like pens, you need to have the speed up there. I generally have it going as fast as it will go, which is around 3000-4000rpm depending on the lathe that I am on.
You will very quickly learn the meaning of Raffin's phrase "let the wood come to the tool" and not try and cut more than the tool will cut. As long as you let the tool cut, the wood will peel off. If you try and force it, as you would with hand carving, it will stop. It is a great mechanism forlearning how to use a skew, as the wood will stop instead of getting a catch. You will find that if you do stop the wood, you will have to tigten the tailstock a fraction to get it to drive again. Overall I like mine, and its a great way to use up all those little pieces of wood.
Russ Fairfield
>I cut a piece off of the shank end of a drill bit that is the same size as the one I used to drill the hole for the bead on the end of the chain, and held in the lathe with a Jacobs Chuck in the lathe spindle. The tip is ground to a spade "screwdriver" shape. and one whack holds the wood in place. It's a whole lot cheaper and works a whole lot better than any of the dedicated drivers.
Ron McKinley
>I made several dozen chain pulls a few months ago without a special drive--just using the small jaws of a chuck. I rounded the scrap between centers and cut a small tenon on one end for the chuck. After I shaped the outside I drilled a 1/4" hole about 1/2" deep, then a 1/8" hole the length of the piece so when I parted off the end the hole would be through........Ron
>I tried it your way Ron but my small jaws on my Barracuda chuck don't really run true, never have. I'll try Russ's plan and see if that works. Otherwise, I'll order the drive.
Thanks again,
Mike
I've made a number of these using Ron's method
Don Henthorn
>also a glue block. I never bothered with the kits or with drilling a through hole. I just drilled hole about 3/8" deep and just large enough for the chain to slip in. then I carefully put epoxy into the hole until the inserted chain brought the level to the top and then hung the chain so it was straight with hole. Never have had one pull out.
