Three Point tool question
>Is there an article on making a 3 point tool? I saw a recent post here on using one and it looked interesting. I also recall something about a making on that had a plumbing fitting hex nut for a ferral and by keeping the flats you could easily align it for sharpening. I have a table project coming up and there are beads on the legs. Seems like a good time to try out the 3 Point tool. Or Not. Maybe I should stick with what I know.
Re: Three Point tool question
Re: Three Point tool question *LINK*
Mike Cunningham (Cape May)
>The link will take you to a video of Stacey Hager using his tool. This video accompanies his article in the fall '05 AAW journal which you can order from the AAW website.
William Duffield, who unforturnately no longer posts here, makes an excellent 3 point tool and has written an article about it. He'll be at my shop Saturday and I'll ask him where that might be found, perhaps the Badger Pond archives.
Mike
3 point video
Check your email
Bruce Wiseman
>Also Darrell Felmate's excellent site has instructions.
http://www.aroundthewoods.com/three.shtml
>Barry The easiest way is to use a hex nut that fits over the shaft of the tool your making. Drill and tap the nut for a set screw. Put this on the shaft and then use every other flat to accurately grind each side. It helps if you grind or file a small flat on the tool so the nut can be replaced in exactly the same spot if you ever need to regrind. I grind the sides to about 45 degrees. Once ground just use diamond hones to sharpen. I've been using mine a fair amount and haven't gone back to the grinder yet.
