Jet 1236 motor problem
Bill Mackey
>Hello; I'm an occasional turner and was doing some spindle work when the motor began failing to start and making a loud hum. If I rotate the turning backward or forward, it will usually start as normal. I believe the motor my lathe has is TEFC. Anyway, I blew it out but still have the same problem. Do I have a capacitator problem (easy to fix) or something more serious on the inside like the brushes, armature or commutator? The lathe is not one of the tools in my shop that is frequently used.
Re: Jet 1236 motor problem
jeff myroup
>Bill,
It sounds like it is the starting capacitor, if it starts while spinning. Should be an easy fix. I would get a new one. They don't cost that much. It that does not fix it, send me an email and we can go from there.
jeff
Starter Cap
Dominic Greco in Richboro PA
>Bill,
I had that same lathe and had the exact same thing happen to me. It was the starter capacitor.
You can buy a replacement for about $3.00 from a motor repair center, or online (Grainger or McMaster-Carr). Take the old one out. Look on the side of the starter cap somewhere and you're bound to see the rating written there. Better yet, take the old starter cap with you when you go to buy a new one. That will help them give you one that will fit in the old housing. Replacing it is a breeze, by the way
One question; Were you using a long extension cord with this lathe? If so, this might have contributed to the starter cap wearing out. I was told that the effort of the motor trying to draw current through a longer extension cord and will eventually cause the starter cap to wear out. I would recommend that you purchase an extension cord rated for use on a Refrigerator or large appliance. They're shorter, but much beefier. I've had one installed on my Jet JWL-1642EVS for several years and have had no problems with it.
Good luck,
Dominic
Bill Mackey
>Thanks to both of you and Dominic yes, I have wired the thing up to run off an extension cord that looks to be 14 gauge. I will replace it with a 12 gauge.
jeff myroup
>12 gauge should be fine, but I always tend to go bigger, when I can. The smaller the gauge wire, the larger the voltage drop over a distance. If you have a 1.5hp motor and the voltage drops, current has to go up, to have the same power out.
jeff
Allen Neighbors
>It's more expensive, but I suggest you go with at least a 10 gauge extension. It will require less power to juice it up. Also, if you have to go over 6 or 8 feet to a receptacle, you should take into consideration how far that recep is from the breakers, and what size wire it is wired with. In some places, the codes only called for 14 gauge wire for many years.
Just my .02.
