Question on Coring
Question on Coring
Question on Coring
Brodie Brickey
>I have the McKnaughton coring tool and I have to say I really like it, for side grain coring (ie standard bowl turning).
Question: Is there a way to core bowls when end grain turning? I tried with a really green piece of wood, but no go.
Thanks,
Brodie
Re: Question on Coring
Cyril Griesbach
>I can't speak for the "Mac" but my buddy has done it with the Oneway. It's slower because of the end grain and I don't see why it can't work with the "Mac".
>I cored a walnut bow that was end grain and about ten inches in diameter and five inches deep end grain with the McNaughton system. It was tougher going than side grain, but it worked OK. The "shavings" came out looking like loose black pepper. One thing I did not like was that I had to core all the way through and cut the inner blank out completely. Normally, I stop when the plug in the bottom of the cut is about an inch or inch and a half and break it off. I even made a curved "chisel" to reach through the coring cut and give the plug a whack. Unfortunately the plug when coring end grain has vertical grain in it and is not going to break and separate like side grain. It would be easy to pull a hunk out of the bottom of one of the blanks. I really don't like cutting all the way through. I just visualize the inner blank getting into a bind against the coring knife and flying off in all directions, namely, toward some body part I prefer to keep unscathed.
George Van
>My experiences have been the same as Barry�s, slower going but then the chips are smaller and seem to clear easier than side grain shavings.
