We value your privacy.
>A question for those of you that apply color to your turnings. Can black shoe polish be used rather than purchasing a product such as Liberon, etc.? I'm assuming, since it is a wax, that it can be used, but want to hear from someone that is experienced in the various coloring processes.
I have used Kiwi black shoe polish on the exterior of ash bowls in a wipe on/wipe off manner. The result was a nice color in the grain which has held up for years. I probably top coated it with some oil/varnish product. I don't recall for sure. I have no experience with trying to make the piece deeply or fully colored.
>All the shoe polish waxes I've tried work great. You can wipe some of it off with mineral spirits if you just want to fill the pores. If you flood the surface it removes a lot if you gently wipe a mostly dry cloth it cleans some off. If you just buff it with a rag it leaves a lot in the finer pores. There are a lot of variations.
It take a while to completely dry so don't rub on it too much. I usually seal it with a thin coat of shellac. Then you can deal with it immediately. You can apply any finish you want after that.
>Absolutely. If you apply any type of topcoat it affects how the wax fills areas and also how easy it is to get off of some of the wood. For example filling Ash, I put a thin wash of either shellac or lacquer depending on what I have handly. Then the wax fills in the pores and is very easy to clean off the smooth wood.
If you do this same procedure without the wash coat the wax will often color the wood. I use this procedure for mahagony or making light woods look like mahagony. I dye it red. Then rub brown shoe polish on. The polish fills the pores and colors the red a beautiful mahagony color.
If you coat the wood without a sealer You can still remove the color of the wax with fine sandpaper after you let the wax dry.It is a little more work and makes the wood look different so try both on scrap.
If you try the mineral spirits wipe on sealed wood it will remove more of the wax, maybe too much so try a dry rag first. If that doesn't remove enough of the wax then try a little mineral spirits on the rag. The nice thing is if you don't like the look you can re-wax and try again.
