200+ woodworking book reviews
? about Mahoney Walnut Oil
Scott Hurley in N. VA
>About 2 months ago, I finished a hickory bowl with Mahoney Walnut Oil. The problem is, after 2 months, it's still tacky. Does anybody know how to get it dry, or should I try to take the oil off with mineral spirits (if possible) and try something else? Thanks.
Scott
Re: ? about Mahoney Walnut Oil
Barry Turner
>You are probably putting on too heavy a coat. I have tried Mahoneys Walnut Oil and have had the same problems. My items have taken a week or two to get acceptably dry...but not as long as yours. The label claims the oil is heat-treated to make it dry and harden quickly. I guess we are just confused about the definition of "quickly".
Joe Herrmann
>I know Mike dips his pieces in the oil so you can't get it on much heavier than that. Sounds like it might be old. I'd either call or email Mike. He's very approachable.
Joe
robo hippy
>I have been using his stuff for about a year on a couple hundred bowls and never had that problem. Lots of oil first, let it soak in, then some of the wax, let that soak in, then gently wipe off excess.
robo hippy
Thanks for the responses!
Barry Turner
>Maybe mine is old too..........
