turning olive wood
turning olive wood
turning olive wood
Bev Thomas
>I am turning a pen with olive wood. Usually I apply about 5 coats of polish but with the olive I get to the 3rd and it starts getting sticky instead of hardening. I've tried to find information re properties of the wood (i.e. is it oily?) but I'm not getting too far. Anybody have any ideas? Thanks
Re: turning olive wood
tek-Brunswick, Ohio
>What kind of polish are you using? More details will help you get a btter answer. Let it sit a few days and see if it gets better or worse. If it gets worse you'll have to take off the finish. Then seal it with shelac and then finish it.
Bev Thomas
>I let it dry completely and then sanded it back to bare wood twice, because each time on the 3rd application it started getting sticky. The 3rd time I only put 2 coats of polish and finished up with stick wax. I was using Lee Valley Turner's Polish. I've done a couple of dozen pens over the past year and have never had this problem before, but then I hadn't used olive wood before.
A different finish perhaps?
Dominic Greco in Richboro PA
>I've turned several pens and bottle stoppers out of olive wood and never seemed to develop the problems you describe. However, I used CA glue as a finish on some of the pens, and Lacquer on other pens and bottle stoppers.
The CA glues worked perfectly. But took a long time. The Lacquer was the easiest. I sealed the wood first with PSI's Lacquer Based Sanding Sealer, then gave then several coats of Deft Spray Lacquer. I allowed the lacquer to harden for a day then wet sanded and polished.
bowlman
>True Olive wood is very oily, just like the fruits (olives!). You could try acetone first, just like you would for oilt tropical exotics, and then a finish. But, even though its a soft finish, why not just use micro-mesh to a nice high number and then buff with carnuba wax? The users fingers will supply additional oil. In time, if the pen needs some renewal, just wipe on some more oil ... extra virgin anybody?
eaglesc
>FWIW
Let it cool between aplications.
I am guessing you are using a shelac based polish.
This will also alleviate the "bloom" that sometimes appears under a finish.
The mandrel will warm up and conduct heat throught he tubes and the blank.
It will take a while.
keith zimmerman, Normal, IL
>I use Russ Fairfield's CA-BLO finish on olivewood and have never had a failure. I sand to 12000 micromesh, then apply the finish.
keithz
Bev Thomas
>Thanks everyone for the suggestions. This is the first time I've seen and used the messageboard and as I live in a rural area, it is great to have access to the experience and expertise of others. One other question: I've seen the micro mesh in my turning catalogue but never used it. I've just stuck with what I started out with. However, as my technique improves, I'm becoming more critical of my finish. Is micro mesh the way to go?
Re: turning olive wood *LINK*
Troy German
>Bev,
Based on the raves of others here I bought Vince's starter kit. The first wood I used it on was olive. By 400 grit it was so smooth I didn't want to stop touching it. I got some 600 grit as well, as it doesn't come with the starter kit. It did make a slight difference, but I still would have been happy with the results from the 400. I beal buff almost everything I turn and I'm not sure I would be able to tell the difference between 600/beal buff and 400/beal buff.
It's also worth noting that the micromesh holds up longer than sandpaper and that Vince was a pleasure to do business with.
Sold on micromesh,
Troy
Vince's abrasives
Bev Thomas
>Thanks for the link Troy. I am confused about the numbers though. The sanding kit I'm looking at includes grits from 1500 - 3600 and the supper finishing kit is 4000 - 12000. It is labeled micro mesh. Is that the same as what Vince labels Blueflex micron?
Bill Crommett
>Bev: There are three different standards for measuring the grit of abrasives, which will leave you quite confused until you settle on what you will use all the time. I do not have the standards at hand, but maybe some one on the board can give you the comparison page, or link.
Troy German
>Thanks Bill,
As with most things, the more I learn the more I realize how little I know. In the past, when someone has said that they sanded to 12000 grit I assumed it was a typo and that they meant 1200. Now I'll look forward to someone shedding more light on the subject.
Troy
sam nelson
>Hi Bev
There is a company in Canada called William Woodwrite. They have nine (9) mico mesh 4x3 sheets from 1500 to 12000 grit for $16.95 Can.
Take a look
Take Care
Sam
Barry Elder
>Hi, Bev,
Haven't been there in a couple of years, but the Micro Mesh site had a where-to-buy search feature and listed one or two kits for woodworkers. Naturally, it's a good place to find out about all their products. Wound up getting my kit from a marine supply outfit in the next town and they even delivered it. Good product. Am not affiliated with Micro Mesh, etc.
