We value your privacy.
>I've read a lot about green wood turning as far as bowls are concerned, but not much as it relates to spindle turning. The reason I'm asking is that I was thinking of making new handles for some old turning tools I have out of some trees that fell over in the neighborhood recently.
Is it advisable to try to turn handles out of green wood, or should I just cut out blanks and wait for them to dry before turning?
>I have tried that using 2 or 3 species of wood and have not had good luck with them. They split pretty bad to the point where they were unusable. I was using sycamore, walnut and ash. However I have used some mesquite that worked well but it does not shrink.
For handles, you should spit the green wood. Do not cut it. You can let it dry in this state or (I) rough turn the tool handles. Put it up to dry or what ever speed up drying process you use. Once it is dry then turn your handle. A green handle will shrink and the tool will come off when you do not want it to. DAMHIKT
>I've had no problem turning green. Some slight distortion, but given my "skills" not an issue. Used copper pipe for ferrules. As for tool coming loose, bang the handle on the lathe with the tool vertical. Given some of mine (and me) are 20+ years old, getting a little weak in the joints seems sorta natural!
>Wilbur Are you riving the wood? I've turned a fair number of chair parts and tool handles and only had splitting problems when I made parts that are larger than 3". I split the wood, stay far away from the heart and don't leave the sap wood in the piece. I usually let it set for few days if the wood is really fresh. If it's been in the log a week or so I don't.
If your going to make a tool handle out of green wood, turn it and then super dry the tenon where the ferrule will go. I put it in a box with a light bulb. I cover the rest of the handle with aluminum foil to keep it from overheating. I leave it about 8 hours or so. Then re-turn the tenon to exact dimensions. I learned this from Curtiss Buchannan for making chair legs.
some woods will split easily. I can tell you that Cherry is one of them. I've mostly turned things like Oak, Walnut, Ash, poplar and Catalpa other local woods. Burl wood and rootballs are always suspect. I have a dogwood mallet that split. It was about 3 1/2" in diameter. I let it split as much as it would and then filled this with colored epoxy. Then I sanded it to shape. I've been using it for at least 5 years now so all is not lost if you do get a big crack.
>I've done legs and handles out of green lumber (usually maple or white oak). I rough them then dry them in a hot box (mine used to be an electric heater in a plywood and blue insulating board cabinet). Let them dry for a while (several days to a week) with foil on the parts that I don't want too dry. Return as necessary to get them back into round. The legs and handles start as rived green wood.
>Thanks for the replies! I'll try splitting/riving the wood, and then letting them dry in that state, then turn them. Unless I get impatient and decide to use the 8/4 white oak scraps I have lying around.
