Processing Semi Dead Cherry
Tom Minehan
>The local power company cut a dying cherry tree on their right of way and told me to take it. I have it cut into manageable lengths. The sap wood in a lot of places looks a little punky for about !/2 to 1" in. The heart wood is fine. There is more wood than I can readily process. I'm wondering if it is better to leave it in the longer lenths or cut it into blanks and anchor seal. The ends now have anchor shield. I'd hate to lose all this cherry because I didn't process it correctly with the punky wood. It is about 16" at the base and the center is all solid no rot.
Re: Processing Semi Dead Cherry
Live Them Long
Jorge Castaneda
>and chunk as you go, that will minimaize cracking, also, keep it in the shade in a rather moist location. Dont worry, cherry does not spoil esdily, but it checks readily.
Jorge
robo hippy
>I have found that standing dead trees will crack and check faster than live ones, especially when you cut them up (can you say shatter?). I don't know why, but cherry has been the worst one for me. Process/rough turn as soon as you can.
robo hippy
Leave them long and seal the ends
Brian Hahn in SW Wisconsin
>I agree with Jorge. Leave the logs long, seal the ends and store in a cool spot out of the sun. I've stored them in a shed for a year or more without problems. You may loose a couple of inches off the ends from checking, but the rest of the log should be fine.
Thanks!
Tom Minehan
Gary Evans Tallassee, TN
>Tom,
Cherry is one of the woods that I would recommend processing as soon as possible. I've seen cherry split inside the log after being dead for a couple of years. I think you are better off to make half-logs out of it, at least. Also, remember that you can get three big natural edge bowl blanks out of a 16" diameter log.
Gary
