Strange chuck
Strange chuck
Strange chuck
eliot d
>My first lathe was an old Sears with a 3/4x16 spindle. I found an old British made chuck for it called a Craft Supplies MAXI GRIP 2000. It adjusts with a tommy bar and a crescent type wrench -- but , apparently , with very limited movements. The four black metal jaws arrange themselves into two more or less concentric circles. The outer dovetail jaws work only in the expansion mode with minimum diameter 7 cm (2 3/4 in) and maximum dia. 8 cm(3 1/8 in); whereas the inner ring, also dovetailed, works only in compression mode from 5 cm down to 4 cm. Each of the four jaw segments has two small threaded holes that accept eight bolts that came with the chuck. Has anyone ever seen one? Do you know what the bolts are for? I wonder if this is only part of a chuck. Any ideas?
Re: Strange chuck
Re: Strange chuck
E.T.
Re: Strange chuck
Re: Strange chuck *LINK*
E.T.
>Check out the Craft Supplies UK web site. Look for chucks. I have tried to add a link to the jaws, butit keeps getting lost.
http:///www.craft-supplies.co.uk/#
Re: Strange chuck
Re: Strange chuck
eliot d
>Thanks ,E.T. The link worked perfectly, and, sure enough, there's the chuck on that site. I used the chuck again for the first time in years, and it's actually a fine little machine. One nice feature is that it has no protruding elements to bash your knuckles. On my new Powermatic lathe, with its 1 1/4 x 8 spindle , I have to use this old Craft 3/4 x 16 chuck with a reducing bushing, and even with this bushing in place, the chuck runs amazingly true. The bolts I asked about must be for adding other jaws. Thanks again for your help.
Re: Strange chuck
E.T.
>There are jaws that attach to the segments with the screws. Look at the Craft Supplies UK site. Links below
http://www.craft-supplies.co.uk/#
