? on drying green bowls
Dave Mount, NE Minnesota
>Hello folks--
I'm not a regular here -- I hang out mostly on the hand tools board, but I was steered over here for this question.
The comparatively short version is that as a greenhorn blacksmith I made a hollowing adze (more on that over on the hand tools board), then used it to hack out a bowl out of a piece of birch firewood. It was just an excuse to do something with my new adze -- I don't own a lathe and have never made a bowl before. This is a very hunky, utilitarian thing, but since I bothered to do it, I'd like to get it dry without it cracking up into pieces. So my question is, how does one dry a bowl like this? I've dried a lot of lumber, but never something like this. I didn't have the patience to work it down real thin, so the walls are comparatively thick, circa 1/2", maybe 3/4" in a couple spots. Thus far (i.e. two days) I've had it in a loosely closed paper grocery bag.
Thanks for any help. And I might add that the work you guys turn (yikes) out is truly amazing.
Best,
Dave
Re: ? on drying green bowls
Dave Belser
>Keep it in the bag in a cool place without much air circ and you should do fine. It looks like there is a fair amount of pith in it which might give you trouble. The other common approach for twice turned bowls is to paint the outside with anchorseal (wax emulsion), but if you do that you will have to remove more wood when it drys out.
I've had realy bad luck with the only birch that I've tried but it was because of other reasons.
Keep an eye on it, look for cracks starting at the center pith. If you see little ones develop, throw it in a closed plastic bag for a few days to slow it down even more.
Good luck, and let us know how it turns out.
- Dave
Richard Allen
Richard Allen
>How about putting a couple of paper towels in the paper bag with the bowl. Put the bowl with the paper towels which is in the paper bag in a plastic bag. Each day take the bowl out of the bags, remove the paper towels. Turn the plastic bag inside out put the bowl in a dry paper bag with two dry paper towels in the inside out plastic bag. Set the paper bag and the paper towels aside to dry so you can use it the next day.
When the paper towels no longer are damp when you do the inside out bag thing then increase the time table of the process to 2 days. Keep increasing the time between the inside out thing till there is a week between and the paper bag and paper towels are dry.
Now ditch the plastic bag and paper towels. Put the paper bagged bowl in a cool dark dry place. In a year the bowl will be dry.
Good Luck
Bill Howatt
>Very nice bowl!
Like the others said, you must slow down the rate of drying to prevent cracking. I put mine in brown paper bags and then put them into a paper yard-waste bag, I often just put them in the large bag without first putting them in the small bags. If it is bowl I really down't want to lose, I will coat it with Anchorseal especially on the end grain but as was mentioned, you then have to remove it when the bowl is dry. This is not a problem for what most of us do since we turn to a rough dimension (wall thickness about 10% of diameter), let it dry and then true up, cut to final thickness and finish.
Be careful of too much moisture since it will cause mold to grow. If the bag or anything else near the bowl is wet, replace it.
I would watch your bowl carefully at the top where the pith is/was. That is likely where the cracking will show up first. You can't stop it so the best thing would be to immediately cut the top of the bowl down to remove the cracking, IMO.
Bill
Bill Crommett
>Just remember that the function of a dry kiln is to remove the moisture from the whole thickness in a uniform manner so that the inner wood ( halfway through the board) is as dry as the outer layers. This takes time, no matter what system you use, and there are species and configuration complications. One of the most notable on bowls is the presence of pith which wants to dry faster than heartwood and hence the cracking potential. If you want a good demonstration of how wood is dried correctly go visit a commercial kiln and watch the process.
Leo Van Der Loo
Re: ? on drying green bowls *LINK*
Leo Van Der Loo
>Hi Dave
You did a very nice job on that bowl, does remind me of one my mother had when I was a kid, however it did have a rather large split in it after many years of use as a mixing bowl.
As the others have pointed out, you do have to slow down the drying of the wood, and I would ad to that, that the whole bowl, inner wood as well as outer wood should dry at the same rate, meaning that you should try to prevent the outside of the wood to dry faster than the inside can get rid of its moisture, problem of course is that the endgrain is able to loose and WILL loose it faster than the rest of the bowl, UNLESS you prevent that, this is the mayor reason why you will have checking/splitting at the pith and endgrain of your bowl.
In your case, I would before I'd place the bowl in a thicker brown paper bag and close it, seal the heartwood end grain, as I think you do still have a relative large amount of wood in the lower part of the bowl, and slowing down the upper part would be a good thing IMO.
A wood sealer like anchor seal or heated candle wax would do the job, and be relatively easy to scrape off when the bowl is dry, you can risk going without, but might end up with a split bowl.
Just my 2 cent,Canadian
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum26.html
John Scheideman
>Do a search for alcohol drying. It is the only way to go! I use it all the time on green, rough turned bowls and rarely have any crack.
John
Keith Newton
>Dave I agree with Leo. Your biggest concern should be the short-grain ends around the pith. The fact that there is a little extra extractive content due to heartwood, will slow it a little, but in birch, that isn't enough.
Part of the problem is with the tight small arcs of the rings, and the ratio of tangental, and radial shrinkage, that adds to the problem, and is really hard to explain, and understand.
I think my advice to you would be to fold a few layers of paper towels around the upper end-grain, with foil formed around that. This will slow that part down enough, that the rest should be fine in just the paper bag.
You may still have some cool weather up there, so keep a close eye on it. I take my work to my bedside with me. In a bag, you can hear the first small cracks crackle before they pop. If you hear that, put the paper bag with the aforementioned in a plastic trash bag for a day. This will allow the internal moisture to catch up with the surface MC.
Feel free to take it out for inspection as much as you like. The knowledge you gain will help in the future works. Working green is great fun, and is cheaper and easier than harder already cured wood. Good luck with it.
Re: Thanks all
>Thanks for all the pointers. I've air dried 1000's of bf of regular lumber, seems like the issues here are pretty much what you would expect from that. I think I may use some shellac to coat the endgrain around the ends. I will also check out the alcohol drying info.
Thanks again for helping out a "flatwork" guy,
Dave
