Tool Gloat
Tool Gloat
Tool Gloat
Ray Binnicker
>LOML approved (not that I have to get approval (:-))and I went out today and brought home a new Jet 1442. Man, what a difference from my old vintage Delta 12"! I can actually turn and talk to someone standing next to me at the same time.
As pleased as I am, do you ever get used to the speed change lever where it is located?
Re: Tool Gloat
Re: Tool Gloat
Lan Brady
>Ray,
It is the only lathe I have ever owned so I never noticed it being in my way. Maybe being left handed has kept me from having to reach across it.
I think you will be happy, Lan
Re: Tool Gloat
Re: Tool Gloat
Dave Neighbors
>I owned a jet 1442 and never got used to the speed control lever being in the way. Also be careful of the spindle lock. Its made from pot metal and the little "gears" that the lever locks against tend to break off. All in all, not a bad machine, but I would think Jet could come up with a different approach to the spindle lock design, and a different location for the speed control.
Re: Tool Gloat
Re: Tool Gloat
B. Leathers
>Same here - Only lathe haved owned so far. Over all satisfied - a few times the motor was in way of bowl blank turning. Switch needed to be taken apart a few times to clean the contacts of sawdust. Speed control gets balkey when the temp falls below 50 - but then again I shoudn't be crazy enough to turn outside in the winter ! Bill L.
