Re: Stacey Hager's Point Tool
Dominic Greco in Richboro PA
>Dave,
You wrote:
"....Lee Valley sells one that looks like a much larger dia. than what Stacy has...Likes, dislikes, sources for it, Instructions for grinding.???
Using information from Stacey Hager's article in last year's "American Woodturner" I made my own 3 point tool from 3/8" drill rod. After using it for some time, I made a smaller version using 3/16" drill rod. I found that I like using the 3/16" version much better. It just seems like it's easier to roll small beads and get into tight spots.
Ever since I made mine, I found that I can roll beads, both large and small, with greater ease and with much greater consistency. This tool has now become my "go to" tool for detailing.
Stacey's article shows how the proper angle and details how to make a very simple jig that will help you form the point more consistently. But I didn't need to make this jig since I used hex compression nuts for my ferrules. It's like I have a built in stop for the proper angle. I just rest one flat of the hex nut on my too rest, adjust the grinder table to the right angel, and go to town.
As far as sources for the rod, ENCO and MSC sell hardened drill rod in all sizes. Look for the M2 HSS stock if you can. Don't get too bent out of shape if the rod is only 6" long. A short tool is perfect for rolling beads.
Of course, you can bypass all this and just buy a 3 Point (or "Pyramid" as some call it) tool from Lee Valley, Packard Woodworks, Or CSUSA. But I believe the smallest diameter they sell is 3/8" (someone correct me if I'm wrong here).
Good luck,
See ya around,
Dominic
