Bandsaw Blades
tm
>Does anybody resharpen their bandsaw blades?
Is it worth the effort?
After vacume cleanout of the inside can I do it with the blade
on the saw?
Method / tips?
Thanks,
tm
Bandsaw Blades
tm
on the saw?
Method / tips?
Thanks,
tm
Re: Bandsaw Blades
Dick Hines
>Not as far as I am conserned. They are to cheap so I just replace.
Re: Bandsaw Blades
>I tend to agree with Dick. If you are running cheap blades they cost so little its hard to justify sharpening them. If you are running expensive blades, I doubt they would ever cut the same if "I" sharpened them. You might get better at it.
Another way to look at it is that if it takes you 15 minutes to change a blade, you can sharpen one on the saw in about 15 minutes, so its almost a wash time wise.
There is at least one article here on how to do it with a Dremel tool on the saw. Maybe someone will chime in and tell you how to find it. Some people are quite good at it. I found the blades were somewaht better than dull but not as good as new. It depends on whether I am in the mood to work "on" my tools or "with" my tools. I bought ten identicle blades so I don't have to adjust the saw in every direction to change the blade.
Re: Bandsaw Blades *LINK*
Cyril Griesbach
>I have not done this myself but I'm thinking of giving it a try. Why not. Nothing to lose. I've also never added a link to a post so if this works it should take you to Steve Russell's article on his process.
How to Easily Resharpen Bandsaw Blades
Re: Bandsaw Blades
Cyril Griesbach
>Holey Moley...it worked! Shows that and old dog CAN learn a new trick:)
Re: Bandsaw Blades
Greg Haugen
>I do sharpen them. Blades are cheap but if I can sharpen one two times at 15 dollars blade I just saved 30 bucks from not buying 2 new blades. I use 1/2" 3 tpi Olson Blades that I buy locally. My chainsaw is the smallest of the three sharpening bits that dremel makes for their chainsaw sharpener. I use those in my dremel to sharpen the teeth. I have the bit in the tool, not the guard for chainsaws, just the bit. The guard gets in the way. I leave the blade on the saw. Mark the starting point on the blade with a sharpie so I can see it when it comes back around. Just bringing the sharpening bit up into each tooth for a second is all it takes. Continue to do this until the sharpie mark comes back around. I started to do this when I was turning a lot of bowls. Cutting elm, locust, or any other extremely dense wood really dulls the band faster than I wanted to buy a new one. I also have a Ridgid 14" bandsaw. It cuts great but with a 3/4 horse motor it will take all of the help it can get to cut a circle in 5 1/2" thick wet locust.
Hope that helps,
Greg
Bandsaw Blades - Sharpening & Setting
Mike Brazeau
>A timely post- I have sharpened a 1/2" 3 TPI blade successfully, but I found I lost some of the set and it was not as good on wet wood for sawing bowl blanks or general processing of spindle blanks etc. Was wandering around our local LV and came across an old fashioned saw set for hand saws. After contemplating for the usual few weeks, I decided to buy one, about $20 Cdn with taxes and yesterday I put it to the test. This time I sharpened in the gullet with a chain saw diamond burr and then reset the teeth quite aggressively, using the highest setting possible on the saw set. Just visually you could tell it was extereme. Measured with a caliper, I added about 10 to 15 thou to the standard set. I probably missed a few teeth here and there, but for rough cutting wood who cares. I ended up with a kerf of 3/32 of an inch. WOW is all I can say! I did a before and after on two hard maple blanks I cut out (11" diameter about 6" at thickest point). I struggled with the first for about ten minutes, giving up on curves and just cuting off corners chain saw style. The second after sharpening and resetting I buzzed through in a couple of minutes with a perfect round like I have never achieved on my underpowered 14" import saw with riser.
For a hobbiest, trying to save where possible, a defintely a great return on investment of time and $. Even if I was a production turner, I think it would be worth the time investment. Mind you, if was into production work, I wouldn't have a 14" saw.
Sharpening Bandsaw Blades *LINK*
Brian Hahn in SW Wisconsin
>I sharpen my rip blades all the time. I've posted a how-to with pictures on the AAW Forums in the "How-To,.." forum. See the link below
Sharpening Band Saw Blades
Re: Sharpening Bandsaw Blades
sam nelson
>I also believed in replacing the blade when dull, until the day I did not have a replacement blade to install. I had work to do with no time to run for a replacement so I used my Dremel and chain saw sharpening bit and sharpened the blade using the information available from this and the WOW sites. I could not believe how well it cut afterwards. Now I sharpen the 132 in. blade in less than 10 min.
Try it, as it does work well
Take Care
Sam
Give it a try
Curly Smith
>I also use Steve Russell's method in Cyril's link. It's a bit slow the first couple of times but you get faster with practice. I do a fair bit of resawing cedar and the blade gets dull rather quickly. If I didn't resharpen I'd either have to strip the bark first or not resaw because the cost of bandsaw blades would be prohibitive.
Brian's method looks interesting. It looks like a more complete sharpening method.
I'm thinking that combining the two methods might be productive. Resharpen with Steve's method on the bandsaw a couple of times, then resharpen off the bandsaw and set the teeth with Brian's method.
Re: Bandsaw Blades
Russ Fairfield
>Here is what it looks like in action, on the saw, with a Dremel "Cut Off Wheel". Dremel makes these in two thicknesses. Get the thicker discs if you can. Stacking two of the discs is a good idea because they are less likely to break. Once you get the motions in sync, it takes about 5-minutes for me to do the 315 teeth on a 105" blade. Use a very light touch of the wheel to the tooth. It doesn't take much.
I can get 2 sharpenings out of a blade. Others have claimed many more.
There is a definite advantage to sharpening if you are buying Olson or cheaper blades - the sharpened blade cuts better and lasts longer than a new blade. There is no improvement on a premium blade.
The downside is that the set in the teeth is ground away.
Is it worth doing?? That is up to the individual doing it.
Re: Bandsaw Blades
robert davis
>the timberwolf on my saw has been resharpened three times. you do not get as smooth a cut but doesnt matter if you are cutting turning stock.easier to sharpen than to change and a wee bit cheaper
Re: Bandsaw Blades
robo hippy
>New Lennox bimetal 150 inch resaw blade about $80. Resharpening at local saw shop $9. It is worth it to me, and they do a better job than I do. I would think that you should sharpen the gullet like a chainsaw.
robo hippy
Re: Bandsaw Blades
Mark Kauder, Phenix City, AL
>I do like Russ does (come to think of it Russ taught me how), but only do it on 3-4 TPI blades, not the finer blades.
I do it especially on my Highland Hardware WoodSlicer resaw blades. They do not have much set in them anyway, and I can get 2-3 sharpenings out of them.
Mark
I sharpen my own...simple
Steve Kubien
>I've got a 3/16" diameter diamond burr which I use in my Dremel. I leave the blade in place with moderate tension and run the burr (running about 25-30K rpm's) through each gullet. Nice light touch. Only enough pressure to maintain steady contact. Takes about 5 minutes on my 100", x 1/2" 3tpi blade. The burr is supposed to be good for about 5 sharpenings. $4 for the burr and the resulting blade performs better than if brand new.
Somebody from the OWG can give you Peter S's contact info (I hope) because I cannot find it).
Cheers,
Steve Kubien
Ajax, Ontario
Re: Bandsaw Blades
Steve Kubien
>While I do not doubt that this method works, it sounds more complicated than it needs to be. See my post below. No worrying about left, right or centre teeth. Just get it done and move on.
My 2 cents.
Steve Kubien
Ajax, Ontario
