Have a question? Ask Woody!
is spalted wood food safe?
Jeff Moore
>I just turned a 12" spalted sycamore bowl which would make a great salad bowl. First, is it safe to use spalted wood in contact with food. And second, what is the best finish for a salad bowl, assuming salad dressings, oil, vinegar will be in contact with it?
Thanks
Jeff
Re: is spalted wood food safe?
Greg Haugen
>This is only my opinion.
In THEORY if its sealed so no contact with the food and mold occurs, then yes. However, in my opinion, no "membrane" finishes will last forever, prefectly sealed and never need maintenance. The oil finishes, Walnut oil or mineral oil, is what I usually use but I would trust them on a spalted bowl. They're are so many types of molds and different reactions people can have to them. If I made a spalted bowl I would probably finish it with a membrane finish and HIGHLY recommend it to be a "fruit bowl" center piece for a table. That way its sealed and it won't be washed and abused like a "utility" bowl would be.
Another thought would be as long as the bowl itself isn't "chewed" on it should safe. In theory that is. But I still wouldn't trust any oils or finishes, because they could "leech" any of the mold out on to the food.
Someone that I trust his opinion of whole heartedly is Mike Mahoney. www.bowlmakerinc.com is his site. He is the utility bowl authority in my eyes. very approachable and talkative. He does get a lot of emails, doesn't always respond. Sometimes he does though. Give him a call. It's not a problem. Double check the "events" page though I think he may be Australia for a Symposium.
Hope it helps,
Greg Haugen
Re: It's what the user thinks that counts
Russ Fairfield
>Black lines and spalt areas may be totally safe, but that doesn't make any difference. People see them as being unclean and unsafe. Nobody will buy a salad bowl with black lines in it, and there is no amount of our telling them otherwise that will change their minds. If you give it away as a gift, they will never use it for the same reason.
Steven Antonucci
The only commission I ever took was spalted maple
steve antonucci
>I couldn' talk her out of it. 4 smaller bowls and one larger, all spalted maple. Go figure.
Steve
Jim King
>We make a lot of spalted salad bowls and the buyers are mostly North American tourists. Maybe its because they get used to eating off cracked restaurant plates here.
