Veritas - Innovation in Tools
Rose Engine
Rose Engine
Rose Engine
woodenLeg
>IN the article it says to "Harden the threads with CA" , How do you do this? I don't remember reading or hearing of this before.
Thanks for the help.
Dave
Re: Rose Engine
Re: Rose Engine
Allen Neighbors
>For wooden threads, if you just run some thin CA down in them, the CA will set and harden the threads. You will have to retap them, once the CA has set. But it really works to keep you from stripping threads at a later inopportune moment.
Re: Rose Engine
Re: Rose Engine
dwr
>I believe it means to use CA glue to harden the threads... especially needed in MDF where you will be using the threads repeatedly.
Dave
Re: Rose Engine
Re: Rose Engine
Russ Babbitt Jr.
>As I learned from Bonnie Klein, when I cut threads for boxes I will coat the threaded area with thin CA before threading. This help insure clean threads when cutting. No reason you could not use the CA after the threads are cut, like has already been said especially in MDF.
Re: Rose Engine
Re: Rose Engine
woodenLeg
>Thanks Guys. Dave
