THE WOODRAT IS BACK!
Offset handled scoop
Mike R Courteau
>A month or 2 back, on Woodworkingchannel.com, I watched a turner make an offset handled scoop. He turns the scoop part first as a sphere, then the offset handle. Then, he uses a sacrificial piece in which he turns a concave and taps the sphere into it to turn off the top of the sphere and create the bowl of the scoop. Does anyone have any idea who this turner is. I think the video was of an AAW demo.
Any help you can give me to trace this turner would be great. I'd like to see if he has a website where I can get some more information.
Thanks
Mike
Re: Offset handled scoop
Re: Offset handled scoop *LINK*
Bill Howatt
>This was the site I found for scoop making info but I don't know if it is of any help for your particular search.
Bill
Turning a Scoop
HeatherA in Alaska
>His name is Soren Berger. His website has a picture of the scoop but no other info that I can see. He is coming to AK next spring to teach and I plan to take his class.
Heather
Soren Berger
Jimmy Edwards
>Soren Berger. Its on again at 8:30 am today. central
Mike R Courteau
>Thanks all. Soren's the one. He's on again a couple of times today so I'll be watching.
Mike
Sean Troy
>I took a class with Soren some years ago and found he was an excellent teacher that's easy to understand. The scoop was part of the class I took. They are not as hard as one might think. His classes and demos are very enjoyable.
Lan Brady
>Mike,
I have watched that same video several times. I like making the scoops. You did not ask, but a suggestion that I use. Instead of making a different jam chuck each time. I have made 3 sizes of chucks from pvc step down pipe connections. I cut 12 slits and use a hose clam to adjust for size.
It is lots of fun experimenting with different handles than Mr Berger makes.
Good Luck, Lan
jeff myroup
>I like your idea with the pvc. I am going to give it a try. Do you have an pics of them?
Jeff
Lan Brady
>Jeff,
Sorry , I don't have pictures.
Lan
