First Finials
First Finials
First Finials
Ron McKinley
>I've turned dozens of finials but these are the first that didn't turn into UFOs! The boxes are, I believe, Box Elder. I bought the wood from Steve Dunn in the parking lot at DWR and it was waxed and covered in dirt and debris and I asked him what kind of wood it was. He said, "Trailer wood". I said, "Huh?" He said it's been in my trailer so long I can't remember what it is."
The finial on the left is Honey Mesquite and the one on the right is Walnut from the NW that I got from Dave Smith at DWR. Both boxes are loose lidded so they can be opened with one hand � for ladies' rings or whatever.
As you can see Cindy Drozda has nothing to worry about from me for a long time � a very long time! GRIN! Critiques are welcome........Ron
Re: First Finials
Re: First Finials
Troy German
>Ron,
It's fun to see people try something new. I'd like to know what you thought of the process. What tools did you use? How did you chuck it to the lathe? All the norrow parts transition quickly back to wider parts (i.e. no stems). When I try something thin it gets kind of spooky (I don't know if its about to break or not); Did you experience something similar?
Thanks for sharing,
Troy
Re: First Finials
Re: First Finials
Ron McKinley
>Yep. Broke many of them before I developed a much lighter touch with the 1/4" spindle gouge. I turned them between centers and turned a small tenon on one end to chuck into the small jaws of the Artisan Chuck (same as the Barracuda2). Then I worked from the tailstock end back toward the headstock, sanding and finishing every inch before I moved on. I think the accepted tool is the skew but I haven't mastered that beast yet! ........Ron
