Rose Engine Lathe - again *LINK*
Bob Fawcett
>Still thinking about it.
How about this for a "cutting frame" ?
mini angle grinder
Bob Fawcett
mini angle grinder
Re: Rose Engine Lathe - again
>I think that would work. I think just about every kind of cutter would work to some degree. Each probably has some advantages and some disadvantages and i don't guess we'll know until we try.
Jennifer@Indy.USA
>Bob,
I don't have this tool, but I know someone who has had two of them and burned them up with use. They now use the small Arbortech and say it is considerably more powerful and robust.
Just an FYI
Jen
Raymond Overman in SC
>I'll second what Jennifer said. A pro friend of mine used one of these on a project and burned one up too. I'm not sure what he turned to next.
>I'll agree with Jennifer. I got the arbortec. It is much larger and more powerful. I think the rose engine work is pretty low power. not like heavy duty carving so it might hold up better. The one on the rose engine plan uses a 1/3 horsepower flex shaft motor and custom cutter holder with replaceable cutters. It was quite expensive to buy. I will probably try to build one before too long. It looks pretty simple if you have access to a metal lathe and mill.
Keith Newton
>Bob, I have one of those, and as stated, it is short on power for what they show it being used for. I also have the arbortec that I normal use for these type of cutters.
However I have found a use for this tool that I just love it for. The arbortec came with a couple of little sanding disk, that can be bought separately. When the abrasive became dull, I pealed it off, and scuffed the plastic backer, sprayed it with high strength contact. I then punch my own little mini disk, 1.5" out of 6" sticky back disk for the random orbit sander.
This is a very handy little detail sander. I use it to follow the little arbortec carver.
Bob Fawcett
>Thanks for all the responses.
Looks like this may not be the solution.
I wish I had access to machine tools. I worked in a machine shop many years ago and could probably make my own, just don't have the tools for metal.
Keith Newton
>Bob, I am not sure what you are looking for, but I bought another long neck tool grinder because it was so cheap. Harbor Freight offers one for about $25. It actually feels pretty good. It has less vibration, an quieter than the other one. The switch will probably go out next time I use it, like their other tools, but I can fix that.
